EP21 - Single Stereo Loudspeakers
Old 7th November 2012, 12:36 AM   #11
gainphile is offline gainphile  Australia
gainphile's Avatar
Well if I'm lucky the three B3Ns will arrive today or tomorrow
Elias, do you have any guidelines about the front and side baffle dimensions? My plan is basically to come up with whatever aesthetically pleasing (it will stand directly in front of me!) ... and equalise accordingly.
http://gainphile.blogspot.com
Old 7th November 2012, 06:25 AM   #12
graaf is offline graaf  Poland
graaf's Avatar
for my part I would say that 23x23x23 cm are minimum dimensions - such is my experience with a simple stereo bipole (that is L and R back-to-back only, without any center or any matrix filtering) with speakers slightly bigger than B3N
Old 7th November 2012, 08:21 AM   #13
Elias is offline Elias  Finland
Elias's Avatar
I've tried front baffle widths between 20-25 cm. Depth could be a little more than width, currently mine is 33 cm but I suppose 25-35 should be fine. The height has settled automatically for around 40 cm.
Usually I cross around 200-300 Hz to stereo dipole basses. The bass reproduction of the box is not a design goal.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 7th November 2012, 08:23 AM   #14
Elias's Avatar
Originally Posted by cT equals piD View Post
But as far as I know a system like your SSS has never been commercialized
Does it prevent you from trying it yourself ?
Originally Posted by Elias View Post
Why don't you try it and you will change your mind.
Old 7th November 2012, 11:54 PM   #15
cT equals piD is offline cT equals piD  United States
The dimensions of my listening area aren't compatible for your proposed type of reproduction. Also I assume that any furnishings in a room obstructing sound radiated by the speaker towards the side walls would not be a good thing, making this type of system not so practical for a lot of people.
I'm not suggesting that nobody would like the type of reproduction produced by your SSS. For example, a fair number of people apparently like the reproduction of the Bose 901. As you probably know, in the Bose 901, eight of the nine drivers of the system face away from the listener, while the remaining one faces toward the listener.
Pete
Old 8th November 2012, 12:45 AM   #16
gainphile's Avatar
This is my thinking of the design currently.
The reason enclosures so thin is to allow addition of 8" woofers (also 3 of them on the front and sides) in case SPL is not enough to transition to the subs.
Subwoofers would be dipoles at 200hz, but eventually will be true cardioid.
gainphile.blogspot.com.au/2012/11/ep21-single-stereo-loudspeakers.html
Old 12th November 2012, 09:55 AM   #17
Colin is offline Colin  United Kingdom
Interesting thread.
This PDF of a 1971 article from Ted Jordan may be of interest. It uses a reflector system with two drivers back to back in a central box. The end result is broadly similar to the SSS but with a greater roll-off at HF from the center 'speaker'.
I tried it many years ago and thought it worked quite well, although only with single cone drivers.
http://www.ejjordan.co.uk/PDFs/Jordan_WW_Feb_71.pdf
Using a pair of reflectors would broaden the use of the SSS to rooms which don't have two adjacent parallel walls and the article gives some guidelines re size and materials for the reflectors.
Old 12th November 2012, 10:14 AM   #18
markus76 is offline markus76  Germany
Banned
There is a thread "discussing" that approach.
All of these unconventional approaches to stereo reproduction can (not necessarily do) sound more realistic when compared to the typical reflection-controlled approach but do they sound better?
In my opinion they do not sound better because they completely ignore how most recordings are created. Just like upmixing stereo for multichannel playback can create a very realistic presentation with certain recordings, it can also completely fail.
Instead of forcing stereo to be what it is not, it probably makes more sense to move on to multichannel which supports a controlled way of delivering a more realistic spatial reproduction.
Old 12th November 2012, 11:44 PM   #19
CLS is offline CLS  Taiwan
Ah, that's an endless debate -- the feel of realistic vs real precision.
For me, if the presentation is reasonable and life-like, I don't really care it's a copy of the recording scene (or master room) or not.
I believe real multi-channel can be excellent. However, to complete the whole thing -- from recording to playback, there'd be so many more possible mistakes than plain stereo. We can't stop that. (no one can)
In comparison, it's nothing wrong keeping the simple stereo format and improving it somewhat in the range we can.
Old 14th November 2012, 10:55 AM   #20
norman bates is offline norman bates  United States
norman bates's Avatar
so, you are not delaying the center driver?
And you have equal and parallel side walls ?
EP21 - Single Stereo LoudspeakersHide this!Advertise here!
Stereo Buffer with a single twin triode Brit01 Tubes / Valves 43 29th July 2009 02:32 PM
Can single PCM56P act as stereo? terranigma Digital Source 1 27th February 2007 09:29 PM
Single or stereo speaker evaluation Salas Multi-Way 23 16th August 2006 09:13 PM
Stereo Single 4780 traw Chip Amps 3 16th February 2006 11:39 AM
Meet belle lab, a new manufacturer of single driver fullrange loudspeakers cdwitmer Full Range 14 11th September 2005 06:23 AM
