Mission 751 Crossover Circuit Diagram
Old 10th June 2017, 10:08 AM   #21
ThetaII is offline ThetaII  United Kingdom
..also, would I be right in thinking that changing this cap combination to a 6.8uF cap, as suggested on the first page, would have the effect of rolling off the treble a bit? ..or is that over-simplifying how it works?
Old 10th June 2017, 10:55 AM   #22
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
The most probable answer why they used a combo of poly/electrolyte capacitor is the simplest one. Either they had a stock of these and/or it was cheaper that way without making too much of a compromise. Increasing to 6.8 uF would elevate lower trebble, lowering XO point, increasing the SPL summed in XO region, which may or may not be a good thing, who knows.
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 10th June 2017, 11:22 AM   #23
Thanks again for the information
Old 11th June 2017, 01:48 AM   #24
system7 is offline system7  United Kingdom
system7's Avatar
From what I've read, the Mission 751 has a rather irritating metal tweeter with a polycone 5" 6 ohm bass.
The ferrofluid is prone to solidifying, but easily replaced:
https://www.bluearan.co.uk/index.php...new=Ferrofluid
I suspect a 7.5R/0.68uF Zobel across the tweeter might help tame the top end.
Rough and guessy circuit below, disregard the level adjusting resistors. It all looks OK to me.
Best Regards from Steve in Portsmouth, UK.
Old 11th June 2017, 08:11 AM   #25
Thanks for the info Steve. Regarding the 'irritating' metal tweeter, I think people have made unfair comment on that in the past - my perception is that it may sound a bit harsh on bright systems. It doesn't appear to have issues on most british or french made sources/amps ...from my experience (some amps tested with: A&R A60, Musical Fidelity A1, Atoll IN200).
Old 11th June 2017, 05:46 PM   #26
dewdrop is offline dewdrop  Singapore
I have replaced the capacitors with Dolan but noticed that one speaker is now more prominent than the other, louder on one of the tweeters.
Now, I have to use the amplifier balance setting to negate this.
Any advice to fix this?
Ed
Old 11th June 2017, 05:47 PM   #27
It should be Solen caps, sorry for the auto correction.
Ed
Old 11th June 2017, 09:44 PM   #28
Hi Ed. You've probably worked out that I'm no expert but my logic says if you have checked the components and solder connections then maybe there is an issue with one of the tweeters/drivers. Did you replace all 4 caps or just the 3.3 and 1uf for the tweeter?
Old 11th June 2017, 11:16 PM   #29
Unfortunately I have already checked for dry solder joints. No luck.
Sent from my SM-G935F using Tapatalk
Ed
Old 12th June 2017, 07:44 AM   #30
What capacitor values did you use?
Mission 751 Crossover Circuit DiagramHide this!Advertise here!
MISSION 778 AMPLIFIER - CIRCUIT? Wendyb Solid State 2 24th January 2012 07:06 AM
LS3/5a vs Mission 751 vs first DIY project philpoole Multi-Way 7 20th March 2007 02:03 PM
Circuit Diagram epacor Parts 1 3rd February 2007 06:42 AM
Help! circuit diagram vodaTube Tubes / Valves 0 8th July 2005 06:49 AM
Mission-Cyrus PSX circuit Will Solid State 5 27th November 2002 02:30 AM
