I have a fully recapped set of Braun L810's that I did myself. No problems until I messed around with the phase switch on my Krell KSP 7B. I am no longer getting a signal in my Right Channel Mid driver. The 2 7" base drives and the 1" tweeter have no issues. Any thoughts. Have I blown a coil or worse, the driver?
How do I trouble shoot this? Any help would be much appreciated. |
#2 |
I would check the coil using a multimeter or a small battery. If the coil is ok, i would check for a bad solder joint in the crossover or a bad contact in the wiring..
#3 |
bobodioulasso could you please explain how to do this. Am I looking for continuity and or resistance? My build skills are good, but analysis is not.
#4 |
Simplest way: using some piece of wire, apply brievely an 1.5v battery to the coil terminals (disconnected from crossover).
If the driver works you should hear some click noise from the driver. If the coil is open you'll get no noise. Or use an ohmmeter (in ohm x 1) and check for continuity (in reality a few ohms). |
| ADS L810 crossover upgrade | ptempel | Multi-Way | 5 | 17th January 2013 05:26 AM |
| Braun T-1000 Valuation | SlunkBoy | Swap Meet | 6 | 18th February 2010 09:55 PM |
| Looking for Schematic for Braun PQ20 | JoergST | Car Audio | 0 | 2nd May 2009 12:35 PM |
| ADS L810 complete or parting out | Slanski62 | Swap Meet | 2 | 8th September 2008 07:26 PM |
| Braun PS1000 circuit diagram | highviewvideo | Analog Line Level | 0 | 9th August 2007 04:15 PM |
