Open Baffle with wheels - diyAudio
Old 30th October 2012, 11:31 AM   #1
oon_the_kid's Avatar
Default Open Baffle with wheels
I was wondering if anybody else have attempted this.
Now, we know that open baffles should ideally be about 3 foot from the back wall. However, open baffles should also be large to improve the bass performance, that means a lot of floor space is wasted whihc could be a challenge for apartment dwellers like me.
Has anybody ever tried mountng open baffles on wheels so you can slide it out when you want to do some serious listening and leave it near the wall when you are not using it or just some casual listening.
An alternative is to use teflon sliders.
Any ideas and thoughts?
Oon
Old 30th October 2012, 11:37 AM   #2
Hentai is offline Hentai  Japan
I like the idea of being able to slide the speakers away when not listening to make more space.
I belive it's pretty close to thos baffles with hinges that allows you to ply the baffles, after listening, into a smaller footprint.
Old 30th October 2012, 01:09 PM   #3
norman bates's Avatar
I found the hinges lower the front open baffle size, and width seems to be ugly, not height.
I like the idea of a rolling baffle.
But I'd like it better flat on the ground.
Old 30th October 2012, 02:10 PM   #4
zmyrna is offline zmyrna  United Kingdom
Endorphine from Kingston Kitchen
link is a good example of open baffle + u frame on wheels.
two important points:
- if there is a woofer, it should be as close to the floor as possible
- the gap between the baffle and floor should be almost zero (felt lining should be okay, I think)
Old 1st November 2012, 12:16 PM   #5
Hi norman,
Won't lying on the ground make the speaker lethargic sounding?
Oon
Old 1st November 2012, 12:19 PM   #6
On a different note. I think 3 wheels will be ideal. Although i think a slide pad with a piece of rubber in between that and the baffle base might probably be quieter than a wheel solution...
Oon
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 04:12 PM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 02:00 AM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 08:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 11:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 30th November 2004 12:09 AM
Copyright 1999-2017 diyAudio
