Old 29th October 2012, 01:20 AM   #1
Default Old tweeter behaviour
I acquired a pair of 15 year old TDL T-Line 3s with original drivers. These have a 30mm metal dome tweeter with 25mm coil. They sounded tizzy and Holmimpulse showed very strong output from 5 to 10 kHz and very weak from 2 to 3 kHz, one much worse than the other. Harmonic distortion was also poor at the low frequencies.
I dismantled the bad tweeter and found the ferrofluid was solid, sticking the voice coil on one side. Cleaning out the ferrofluid got a fairly flat response and low distortion, so I did the other tweeter as well and now the two tweeters are closely matched.
I was surprised that the drying ferrofluid actually increased sensitivity at the high end. Has anyone else seen this?
Old 29th October 2012, 12:57 PM   #2
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
Many drivers have complicated resonaces in the upper spectrum. Getting the coil stuck can have shifted something that make it resonate at the top.
Old 29th October 2012, 05:01 PM   #3
There's a page from Roger Russell dedicated to McIntosh speakers and he mentions several times that this is one of the problem with ferrofluid-cooled tweeters.
Old 30th October 2012, 12:11 AM   #4
I am thinking that ferrofluid thickens quickly, even in the showroom - I have seen the same demo speakers in the shops for 5 years+ and is the cause of metal domes reputation for harshness
PTC Behaviour jayam000 Solid State 11 4th May 2009 03:35 AM
Microphonic behaviour Onvinyl Solid State 10 22nd February 2006 10:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
