Old 30th October 2012, 10:08 PM   #31
sideways's Avatar
Ditto...
But to those others...have you ever listened to a Morel driver?? Implemented a Morel driver??
Don't knock it till you try it LOL!!
Anyhoo...back to the task at hand...did what you said Steve...sorta...put a 3.3ohm resistor inline with a 4.7uF cap on the positive side of the tweeter and wired it up in phase...the woofer I left on its own with nothing...results??
Actually quite stunning!! I won't say perfect but a heck of alot better than I would ever have imagined!!
Bass needs a bit of boost which I did with my tone controls on my Mac...otherwise it could be a bit tighter...as it stands, it's nice, warm, full...almost there!!
The Visaton...what can I say...fantastic tweeter...so rich and smooth and I really did nothing LOL!!! Not sure if there is anything else I need to do...will listen for a couple of days to get the hang of these things...more material has to be played
It might be a tad hot in that 3k region...probably the suspect region where the 2 drivers meet...the reason I say that is piano is a tad bit hard rather than organic...less fluid...
I can't say enough good things about that ceramic tweeter...worked extremely well with the DEQX and now on it's own, it's almost magical!!
Toodles for now!!!
Old 31st October 2012, 02:03 AM   #32
sideways's Avatar
k...just ordered the parts for your test xover Steve
If a simple cap\resistor showed some promise this'll be worth it!!
I'll keep you posted!!
Thanks!!!
Old 31st October 2012, 02:15 AM   #33
just another
wintermute's Avatar
I've taken the discussion of morel and zaph with sreten off line, but just wanted to make clear I don't have a problem with zaph's measurements as a whole and in no way was implying that they shouldn't be trusted. There was only a single measurement which I had done that disagreed with his and the discussion between him and myself on that can be seen here --> Morel MW144 deceitful specs
I can see that my grain of salt comment could be construed as being aimed at all measurements he does but it was more meant to mean that there is nothing that should be beyond questioning (importance of distortion included) and is more applicable to those speakers for which he doesn't have a unit to unit consistency rating (because his sample size was two or one drivers only).
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 31st October 2012, 02:35 AM   #34
system7 is offline system7  United Kingdom
system7's Avatar
Yes, it's very boring and disruptive to turn a build thread into a discussion of whether you "approve" of a particular driver or such. The thing is to do the best you can with them since they are already purchased.
A metal tweeter tends to sound metallic. That's just what it does. A question of its harmonic nature. You do notice it on classical piano particularly.
I was wondering if we can get that tweeter filter behaving more suitably and rolling off more steeply to avoid overlap with the bass. It can be done with a third order filter which I found in my archive. I enclose an example for future tweaking experiments. That scheme should match your Morel quite nicely, with some small tweeter diffraction effects not included here as it goes. Haven't modelled it for your particular tweeter, but that would be your starting point.
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK.
Old 31st October 2012, 11:10 AM   #35
Dissi is offline Dissi  Switzerland
Hi sideways,
I could make a proposal for the crossover, but I need to know all cabinet dimensions and the driver positions on the baffle. A picture of the box would also help.
Old 31st October 2012, 11:54 AM   #36
sideways's Avatar
Hey there
K...internal box size...8.5"x9"x13"...internal volume ~15L...front ported tuned to Fs of the Morel...tweeters are offset like a ProAC with the port just off to the side of them and lower towards the centered Morel driver...
I would like the simpliest xover as to keep coherency between the drivers as best as possible...this tweeter tends to be so lovely and rich...very nice on vocals and jazz that I would not want it to be surpressed..or at least that much seeing a simple series RC tends to give it a slight boost in the 3-5K range making vocals a little too pronounced for my ears...too much energy coming out
Cheers!!
Old 31st October 2012, 12:58 PM   #37
I propose a classic 2nd order crossover at 2.2 kHz.
Old 31st October 2012, 09:17 PM   #38
sideways's Avatar
Thanks for this!!
Looks similar to the one Steve put out...
I have the parts ordered for that one already...see how it goes...can always tweak up to yours!!
Old 31st October 2012, 09:38 PM   #39
tinitus is offline tinitus  Europe
Originally Posted by system7 View Post
sideways, reference your query on good test values to try on the crossover, I include a sim.
you forgot a zobel for the inductor
Dissi have the zobel
but I would use bigger resistor
never less than driver dc
and the same goes for all my paralel inductors
on Dissi's xo, if you mount the 1R8 att resistors on either side of the inductor, after the series cap, maybe you could get away with slightly smaller cap, but only 'maybe'
it can be quite effective to fine adjust with those resistors
Old 31st October 2012, 10:07 PM   #40
sideways's Avatar
Isn't a zobel to tame a rising response for the tweeter??
3 way xover help Chrisssssssss Multi-Way 2 3rd March 2006 12:38 PM
Xover jwatts Planars & Exotics 0 8th February 2005 05:01 PM
Xover Ruben Multi-Way 0 21st October 2003 01:05 PM
Need help with xover!?!? WhiteBoyChriss Multi-Way 3 20th November 2002 07:03 AM
Sub Xover HELP! Axeman Multi-Way 2 5th April 2002 09:11 PM
Copyright ©1999-2013 diyAudio
