Need help with a xover please... - Page 3 - diyAudio
Old 30th October 2012, 12:56 AM   #21
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by system7 View Post
I'm interested in Morel drivers, as it goes. People here slag them off for reasons I really don't understand.
I don't understand that either. On of the loveliest tower speakers I've heard (several times) is the Gershman Sonogram, which uses Morel drivers. Beautiful vocals!
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 30th October 2012, 06:13 AM   #22
wolf_teeth's Avatar
I like them alot too!
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 30th October 2012, 11:49 AM   #23
sideways's Avatar
Hey Steve...can I use resisters instead of the coils for testing?? No one locally carries inductors...I would have to order them in...thanks!!
Old 30th October 2012, 12:31 PM   #24
just another
wintermute's Avatar
I like my morel's too I think that zaph has a lot to do with the bad rap because he said they were terrible, and I guess people just take his word for it. I had a discussion with him over the MW144's because his measurements were nothing like mine, couldn't possibly have been the same drivers, most likely the ones he tested were faulty/damaged.
for a different (but outdated) slant on morel drivers this from the web archive of the LDSG LDSG - Morel recommendations
Tony.
edit: and yes Pano, vocals are excelent!!!
Any intelligence I may appear to have is purely artificial!
Last edited by wintermute; 30th October 2012 at 12:32 PM. Reason: comment on vocals
Old 30th October 2012, 12:38 PM   #25
sideways's Avatar
Totally agree...one of the best drivers for vocals!!
Old 30th October 2012, 05:13 PM   #26
system7 is offline system7  United Kingdom
system7's Avatar
Yup and no. You don't use a series resistor on a bass unit, it just kills the damping and gets hot. You could run the bass driver with no crossover components at all. Treble can run on a single, say, 4.7uF or bigger capacitor for now. I'd put a 10W wirewound of about 15 ohms across the tweeter though. Controls the Fs resonance a bit.
Some people like that sort of sound. Phase and tweeter polarity might work either way.
Best Regards from Steve in Portsmouth, UK.
Old 30th October 2012, 07:44 PM   #27
diyAudio Member RIP
No distortion measurements, and Zaph's bugbear with both Morel and Dynaudio.
Its not a question of believing him, for what reason should I disbelieve him ?
rgds, sreten.
Old 30th October 2012, 08:22 PM   #28
just another
wintermute's Avatar
Hi sreten, I take everything with a grain of salt after measuring the same drivers and getting VERY different results. I'm talking about gross differences in T/S parameters, mine reasonably close to factory specs, his no where near them. If those measurements were suspect, then IMO all the measurements (for that driver) were suspect.
He doesn't have the MW144 measurements up any more, if he did I'd show you the differences
edit: if distortion performance is high on ones priority list then zaph's evaluations will have a lot more relevance, than if someone does not believe that distortion performance is a high priority IMO he will slam an otherwise excellent driver if it's distortion is anything but vanishingly good
Tony.
Last edited by wintermute; 30th October 2012 at 08:27 PM. Reason: add comment on distortion
Old 30th October 2012, 08:50 PM   #29
diyAudio Member RIP
If you have a problem with Zaph, fair enough, not my problem.
But I will say given the sheer number of drivers he's tested, and some do
meet near spec, intimating your testing is more accurate is very dubious.
Zaph is entitled to his opinions on distortion versus driver value, you can fix
response issues, you can't change distortion profiles, that your stuck with.
rgds, sreten.
Old 30th October 2012, 08:57 PM   #30
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by sreten View Post
Zaph is entitled to his opinions .......
ofcourse, its his site
3 way xover help Chrisssssssss Multi-Way 2 3rd March 2006 12:38 PM
Xover jwatts Planars & Exotics 0 8th February 2005 05:01 PM
Xover Ruben Multi-Way 0 21st October 2003 01:05 PM
Need help with xover!?!? WhiteBoyChriss Multi-Way 3 20th November 2002 07:03 AM
Sub Xover HELP! Axeman Multi-Way 2 5th April 2002 09:11 PM
Copyright 1999-2017 diyAudio
