I have planed to build 3 way speaker. But have not midrange driver yet, just Woofer and tweeter (SB Accoustic 6" SB17NRXC35-8 + Twitter : vifa XT25TG30-04 . Does any one can help me to give advise what compatible midrange for these drivers, the driver below :
1. Woofer SB Accoustic 6" SB17NRXC35-8
Nominal Impedance = 8 ohm
DC resistance, Re = 5.7 ohm
Voice coil inductance, Le = 0.15 mH
Effective piston area, Sd = 118 cm2
Voice coil diameter = 35.5 mm
Voice coil height = 16 mm
Air gap height = 5 mm
Linear coil travel (p-p) = 11 mm
Magnetic flux density = 1.0 T
Magnet weight = 0.54 kg
Net weight = 1.56 kg
Free air resonance, Fs = 32 Hz
Sensitivity (2.83 V/1m) = 89 dB
Mechanical Q-factor, Qms = 5.0
Electrical Q-factor, Qes = 0.36
Total Q-factor, Qts = 0.34
Moving mass incl.air, md = 11.0 g
Force factor, Bl = 5.9 tm
Equivalent volume, Vas = 44.5 liters
Compliance, Cms = 2.25 mm/N
Mechanical loss, Rm = 0.44 kg/s
Rated power handling = 40 watt
2. Twitter : vifa XT25TG30-04
Nominal Impedance = 4 ohm
Nominal impedance [ohm] 4
Voice coil resistance [ohm] 3.0
Nominal power [W] 140
Short term max power [W] 950
Long term max power [W] 400
Operating power [W] 5.3
Sensitivity [dB] 91.5
Frequency range [kHz] 1.5-40
Free air resonance [Hz] 500
Voice coil diameter [mm] 25
Voice coil height [mm] 2.2
Air gap height [mm] 3.2
Voice coil inductance [mH] -
Eff. diaphragm Area [cm²] 5.4
Moving mass [g] 0.30
Magnet weight [g]/[oz] 240/8.5
Force factor [Bl] 2.5
VAS [l] 0.017
Qms 2.50
Qes 0.71
Qts : 0.55
thank..haryo
VAS [l] 0.017
Qms 2.50
Qes 0.71
Qts : 0.55
thank..haryo
B 80 - 8 Ohm
and on this small size, Monacor have a few new improved hi-Q verisons of older proven designs
dont know if they actually are better, but the old 5" SPH130 have had very good reputation
i havent tryed this one but there´s a thread here about it , search for scanspeak 10F
10F/8424G00 - Scan-Speak 4 inch wideband coated fiberglass - Europe Audio
what does it mean B 80?
should be a link ?
its a new Visaton 80mm midrange
hmm, If I were doing a three way I would not have opted for a 6" for the woofer, probably an 8" minimum and maybe a 10" or 12"!!
I've got a couple of these SB Acoustics :: 4" SB12MNRX25-4 which I haven't managed to use yet, but I felt that they would make excelent mids in a three way
Tony.
Tony.
actually, Im thinking about a 2.5way using SB 8" and 6" together
tweeter could be anything, but definately a waveguide in any case, somehow
- 3 way speaker, need midrange
