Need help for crossover building - diyAudio
Old 23rd October 2012, 02:08 PM   #1
Default Need help for crossover building
Hi am new to the forum.
I need help to build a pair of passive 2 way crossover using the below drivers.
LF - RCF - L15 854k - Attached Specs
HF - P.Audio - Pre Neo 450N - Attached Specs
Horn - same as in Nexo Ps15
PreNeo-450N.pdf
The cabinet design is a copy of NEXO PS15.
Since i don't know much about crossover frequency. I need help in building a crossover that is suitable and can the most out of these drives.
Thanks.
Old 23rd October 2012, 10:02 PM   #2
xjr100 is offline xjr100  Europe
multisono, I do not belive in "building crossovers without measuremets". The best way to you is obtain some measurement equipment (soundcard+mic+software) and do basic measurements of your drivers in cabinet.
Then export results here and people can assist you to build crossover.
From your side only measurements will be required, members can help with modelling the crossover.
Auricap XO, Mundorf, Jantzen capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 24th October 2012, 01:49 AM   #3
Passive Crossover Network Design
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 24th October 2012, 02:43 AM   #4
Pano is offline Pano  United States
Pano's Avatar
As xjr100 said, you really need to measure; otherwise it's just an educated guess. Could be OK, but probably not great.
What is the speaker use? Home or professional?
Old 24th October 2012, 06:00 AM   #5
Pano... The speakers are to be used for Professional - Mainly Mobile Sound system powered by YAMAHA power amp - P7000s.
Felt sorry but may i know what type of measurements needed.. or any Tips here on the Forum regarding the HOW TO Do the measurements?
thanks
Old 25th October 2012, 12:09 AM   #6
Pano's Avatar
For acoustic measurements you'll need a measurement mic (and maybe power supply), a soundcard and some free software. For impedance measurements you can buy a device, or do it by hand with a volt meter.
A crossover for this type of speaker is not easy to design well. You probably did not realize how big a task you have requested! Without measurements, we can get you something that will work, but may not be optimum.
Take the Speaker Voltage Test!
Old 25th October 2012, 02:27 AM   #7
Speakerholic
Cal Weldon's Avatar
Is it time to think about an active XO and another amp?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 7th November 2012, 04:49 AM   #8
Hi i only needs to know the crossover design and components value needed for the speakers to do some tests. Thanks
Old 7th November 2012, 10:40 PM   #9
to work out the component values, first you need impedance plots of the drivers - you need to find the actual impedance of the drivers at your crossover frequency. If you can't measure, you may be able to find them on the manufacturer's web site.
Then, you need to choose a crossover frequency. Looking at Frequency response plots is the best place to start. Once again, if you can't measure, look at the manufacturers site.
If you can post links to the impedance & freq response charts, then we will be able to help with the next step, choosing crossover freq & order.
Building a Crossover wolfsvein Multi-Way 2 22nd January 2009 04:39 AM
Help building 3 way crossover MAXIMUSuk Multi-Way 3 2nd July 2008 07:23 AM
building my first crossover jaygeorge1979 Multi-Way 27 28th November 2007 05:36 AM
Importance of building your own crossover? patchwork Multi-Way 23 3rd January 2007 10:46 AM
help building a 3 way crossover harrisni Multi-Way 6 25th September 2006 04:50 PM
Copyright 1999-2017 diyAudio
