Best driver placement for 4 drivers
Old 24th October 2012, 01:06 AM   #11
Silent Screamer is offline Silent Screamer  Australia
Originally Posted by Moondog55 View Post
All other considerations aside there is something massively imposing and impressive about stacking vertically.
I did think that there was a technical reason for keeping to a maximum of 2 co-incident drivers tho, and this is why WW MTM WW layouts are so common when using quads of woofers
I had contemplated that... with putting only two mid woofer drivers below the mids and two above, it allows a fairly comfortable fit below, and allows the tweeter to be placed optimally at ear height.
Originally Posted by Cal Weldon View Post
You can cheat a little bit by staggering them.
That did cross my mind as I was trying to get off to sleep, I had a quick 2 second look at the 4 drivers placed in a square in Edge last night, and it popped into my head that perhaps it would be interesting to see if offsetting them like in your picture might help flatten the graph.
Old 24th October 2012, 01:21 AM   #12
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
WW -MTM- WW is how I have ( in my head ) the design of my own big open baffle project, trouble is I do not have a room or hall big enough to actually use my design in and my planned OB also needed subs below 40-60 Hz anyway as the big Jaycar paper coned woofers only have 3.5mm of excursion before reaching mechanical limits ( these are the 12 inch DFR'd woofers - I have a dozen waiting to be used ) they went to $29.99 each so I bought all I could at that price
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 24th October 2012, 01:34 AM   #13
I think I would need to do something like MW MW TW M M MW MW because of the shape of the tweeter, and do the woofer separate.
Due to the amount of drivers I am using I have kind of resigned myself to using two boxes per side to house them all.
Another option I could put all 4 mid woofers together and put the mid / tweeters on top of the woofer.
Old 24th October 2012, 01:34 AM   #14
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
A square, with a big central phase plug
Best driver placement for 4 driversHide this!Advertise here!
driver placement speedie Multi-Way 4 9th August 2009 05:22 AM
Driver Placement on baffle 56oval Multi-Way 2 26th July 2009 06:25 PM
Driver placement in horn? Rademakers Multi-Way 4 3rd June 2008 11:58 PM
Dimensions and driver placement Tai-Pan Multi-Way 5 16th December 2002 05:49 PM
Driver placement Vivek Multi-Way 8 12th April 2002 08:58 PM
