Anyone used 0.01uf caps in passive crossovers? - Page 2 - diyAudio
Old 24th October 2012, 02:18 AM   #11
Pano is offline Pano  United States
Pano's Avatar
Thanks. 0.1uF makes sense, you should just be able to hear that on a tweeter, but 0.01uF strains the imagination - even on an electrolytic.
Old 24th October 2012, 08:07 AM   #12
wolf_teeth's Avatar
Originally Posted by system7 View Post
I have also seen commercial speakers with metal tweeters where a 50 ohm 1 watt metal film is shunted across the tweeter. This realy ought to do nothing, but it will stop the speaker impedance going very high at ultrasonic frequency, so might help amp stability.
Nope- that's not the purpose at all. When you take into account the varying impedance of the tweeter against that 50 ohm resistor, all of the measurement points across the Z plot get paralleled with the 50 ohms.
My guess for this resistor usage, as I've done it for this purpose, is to minimize the effective Fs magnitude as it should do. 50 in parallel with a 25 ohm Zmax nets a new Zmax just below 17 ohms, but 50||4 = 3.7 ohms; or a minimal change.
Back to the topic...
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 24th October 2012, 08:06 PM   #13
tvrgeek is offline tvrgeek  United States
Originally Posted by ringo_the_hifi View Post
Cheers chaps... Well, still listening so I'll report back on the decision.
I feel it's got something to do with speed, things seem to sound that little bit clearer/quicker/airier. Does this make sense?
Easy to say (as I've done it) that there is no difference because I feel it's more apparent on certain recordings.
"Speed" One of those words used by people who have not had the time to understand how speakers work. No, the caps have nothing to do with "speed". They have to do with value, ESR, DF and non-linear distortion. Basically, improving all three.
Old 10th March 2017, 12:57 PM   #14
i recently acquired some Vishay 10nF MKP caps from Parts Connexion. After running a couple of WT2 ESR vs Freq. scans, it quickly became apparent why even a cap with that low a uF value can function as a bypass cap. Examine the data column heading labeled R-real. Those are the ESR values.
Going from 10 hz to 20 kHz ESR declines from a few thousand ohms (@13 hz) and starts to decline significantly at 100 hz and decline below 10 ohms at 400 hz and by about 2 kHz has fallen below 1 ohm and settles down in the mohm range (about the same values as a NPE cap) the rest of the way to 20 kHz.
For me, the interpretation of this data points to the bypass caps ability to pass a signal in the HF range and thus supplement the output of the main tweeter's cap.
Initial listening tests with my 'control' music selections indicates the finding above is true. I'm in the process now of breaking in the new Vishay caps bypassed in my Intimates speakers with some pink noise for many hours.
"It's all about the music!"
Old 10th March 2017, 04:58 PM   #15
eriksquires's Avatar
I have tried 0.1 across larger Clarity MR caps and they really enhanced low level detail.
However across the smaller values MR it did change the FR but not the detail. It was definitely due to pure uF changes.
As a rule of thumb, I try to bypass with around 1% of the cap's value. Maybe a little more. In some cases, such as trying to build a larger cap it may be worthwhile to use a larger cap.
I should also point out that YMMV. Even among the same brand/line, smaller caps (< 4uF) may benefit not at all from bypassing, while larger caps definitely will. So having a good ear, skeptical but open mind is key to finding this for yourself.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 10th March 2017, 06:17 PM   #16
My bypass application involves a 4.7 uF CC MR cap.
Old 10th March 2017, 07:29 PM   #17
Hey SD! I think you were the one who turned me onto Audyn TC as good bypass caps.
I tried bypassing on a 3rd order high pass crossover. As usual, the 2nd cap is about 3x larger than the first.
I've tried bypassing the smaller cap with both Audyn TC and Duelund silver foil caps. 0.1 and 0.047uF respectively.
The Audyn did change the sound, but it seemed to be more of a tonal balance change than microdynamics. The 0.047uF cap had no difference.
On the other hand, bypassing the larger cap made a very big improvement to my ears.
This HP section is feeding a Mundorf AMT.
Best,
E
Old 10th March 2017, 07:35 PM   #18
Best,
E
The Intimates HP section is also a Mundorf AMT.
Old 10th March 2017, 07:37 PM   #19
Best,
E
I plan to run some additional WT2 tests on some of my spare low uF caps. Will let you know what affect they have on ESR. I know for sure I have some 0.1's.
Old 10th March 2017, 08:03 PM   #20
I have CMR caps sitting on my desk, waiting for me to feel well enough to risk putting a hot solder iron in my hands.
The one person I know who has upgraded raved. If they are at least not in need of bypassing, that will be better!
Best,
E
What do you think of passive crossovers? Boscoe Multi-Way 333 20th February 2017 05:48 AM
Where is the point of diminishing returns with caps in passive crossovers? PDXMike Analog Line Level 14 2nd April 2012 09:40 PM
Do bypass capacitors work on passive crossovers and what about shunt caps. . . erickalan77 Multi-Way 4 17th August 2011 04:52 AM
passive crossovers.... stuman Subwoofers 10 8th December 2009 02:44 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright 1999-2017 diyAudio
