#81 | |
Thanks Scott. It's an interesting concept. A little too modern for me. Plus, the curved grill would make stretching cloth over it a bit difficult.
John k.... Music and Design NaO Dipole Loudspeakers. |
#82 |
Wanna see!
Markus |
#83 |
Are you sure? It's just a basic model.. The stipulation is that you not share/distribute it - if yes then PM (forum mail) me with your email contact and I'll send it to you.
perspective is everything |
#84 | |
![]() I can understand not liking the design. (..a bit of "tacking" can accommodate the grill cloth - it wasn't designed as a "removable" design.)
#85 |
My point about the grill cloth is that while it could be tensioned vertically any side to side tension would flatten the ark. There would have to be some kind of support behind the cloth, like perforated metal, to maintain the curvature when the cloth was stretched.
#86 | |
Another possibility is layered vertical strips like a vertical blind curtain. If the strips are shear enough it might make for an interesting solution. (..it's interesting enough that I might alter the model to include this to get an idea of the result.)I should also note that the curved portions are just one aesthetic choice (that I preferred) - you could always go back to a panel-like box shape. Just make sure to get the proportions "right" and make it symmetrical with the rear.
perspective is everything Last edited by ScottG; 14th November 2012 at 09:42 PM. |
#87 |
I just looked through listings on fine wire mesh that could be used as a support base.. not cheap at about $5 a sq. foot.
Still, a synthetic organza + starch should perform similarly.
#88 | |
#89 | |
In my experience at 2.5khz the rear tweeter is only marginally needed. At 6khz hopefully it's not needed anymore ?
http://gainphile.blogspot.com |
#90 | |
![]() Note: I *like* the reveal. It gives depth to the design. At once you can see a monolithic view while also seeing the technology behind it - sort of like a fine watch with part of the mechanics shown. Suggestion: put your best "pic" forward on your website; i.e. replace the open view version with this new pic. (..I'd at least get a metallic paint finish for the sub box in the rear (that's currently red) to match the mesh in front though. )Did you know that Madisound has a metallic fabric they are selling for "grill" cloth? (..not a lot of help structurally, but still interesting): The Madisound Speaker Store
perspective is everything Last edited by ScottG; 14th November 2012 at 11:17 PM. |
| NaO Note preview | gainphile | Multi-Way | 161 | 19th December 2012 10:53 AM |
| NaO II RS | gainphile | Multi-Way | 18 | 7th March 2012 10:28 PM |
| NaO II and miniDSP | john k... | miniDSP | 27 | 31st July 2011 11:51 AM |
| FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" | Joseph0 | Swap Meet | 1 | 24th May 2006 05:17 AM |
| RS Labs RS-A1 Tonearm New Unused Boxed | mozfet | Swap Meet | 4 | 6th September 2004 10:51 PM |
