NaO Note II RS
NaO Note II RS
Old 24th October 2012, 04:18 PM   #21
454Casull is offline 454Casull  Canada
Will the 3/4" dome tweeters be able to provide enough SPL at the low end of their passband?
Old 24th October 2012, 05:43 PM   #22
Toaster is offline Toaster  United Kingdom
Surely not an issue for either 6 or 4kHz?
Old 24th October 2012, 08:00 PM   #23
john k... is offline john k...  United States
john k...'s Avatar
The tweeter is capable of max power of 40 watts which translates to 113 dB/M. There should not be any problems with the crossover at 4k or higher, 4th other or higher.
To answer the question about where I am headed. I am continuing to refine my dipole speaker designs by achieving better control of directivity and also trying to make the speaker as economical as possible for the DIY community. Music and Design is a for the love of it venture.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 25th October 2012, 03:52 AM   #24
Melo theory is offline Melo theory  United States
Melo theory's Avatar
That's a crazy looking baffle SL has there!
Looks like a Vase or a lantern.
I LIKE YOU
Old 25th October 2012, 04:03 AM   #25
norman bates is offline norman bates  United States
norman bates's Avatar
why do people care so much for flat sound ?
I had a buddy who made and sold speakers for a store (early 80's).
People always bought his speaker that had the midrange shelved down by a few db over the same components that masured flat.
Norman
Old 25th October 2012, 04:19 AM   #26
Norman
I don't understand compensating for the Fletcher–Munson curve when eq'ing loudspeakers, we can't tailor sounds in real life to compensate for the curve.
Sound pressure should be the same for all frequencies in loudspeakers to mirror real life? No?
I LIKE YOU
Old 25th October 2012, 04:23 AM   #27
Maybe a little boost on the top end, to counteract HF loss in a furnished room.
But then again, a downward slope at HF would sound more natural because it adds perceived distance from the source.
I LIKE YOU
Old 25th October 2012, 07:59 AM   #28
markus76 is offline markus76  Germany
Banned
Speakers with "built-in" HRTF-like distortions theoretically work but the problem here is that HRTFs are not the same for each and every person. Furthermore room interaction will interfere with the speaker's HRTF-distortions in unforeseeable ways. Not a good approach in speaker design.
Old 25th October 2012, 10:55 AM   #29
john k...'s Avatar
Let's assume for a moment that the recording engineer mixes the recording using flat monitors. Then why would there be any need to correct for HRTFs or anything else for that matter. It should be "build in" to the recording. Cutting, boosting or any deviation from the response of the monitor is simply saying 1) the recording engineer got it wrong, 2) the speakers being used for play back are significantly different from those used for monitoring, 3) the listening environment is significantly different that that used for monitoring, 4) personal preferences are different.
This is why I design for flat response. I don't claim it to be correct for everyone's room, recording, or preferences, but it provides a standard reference from which the listener can make his own adjustments using the controls I build into the speaker/crossover. And with this new Note using a dsp crossover the listener has great freedom to tune the system to his environment and taste.
I also feel that when I design a speaker I need a fixed reference. For example, how would I be able to evaluate the difference between the Note and the NaO II which could be attributed to polar response if the two system had different axial response?
And as I said when this was discussed before, if there is a need to correct for HRTFs then it should be done in the recording, not the speakers. And if not the recording, perhaps somewhere else in the play back chain; the CD player, a change in the RIAA phono curve, the preamp, the power amp... It just doesn't make sense that every recording engineer got it wrong on every recording.
Old 25th October 2012, 11:04 AM   #30
Banned
Amen but you also have to admit that a CD speaker from top to bottom is not what is used in mixing/mastering.
NaO Note II RSHide this!Advertise here!
NaO Note preview gainphile Multi-Way 161 19th December 2012 10:53 AM
NaO II RS gainphile Multi-Way 18 7th March 2012 10:28 PM
NaO II and miniDSP john k... miniDSP 27 31st July 2011 11:51 AM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
RS Labs RS-A1 Tonearm New Unused Boxed mozfet Swap Meet 4 6th September 2004 10:51 PM
