Impedance Bass Reflex - check up Beyma 12B100R
Old 17th October 2012, 03:42 PM   #21
Audio Elite is offline Audio Elite  South Africa
Yes you will be supprised, they can play there are good spl as well. I know one guy that used 2 of them in a sub using the O Audio plate amp to drive it! Very musical and quick.
Old 17th October 2012, 03:44 PM   #22
jzagaja is offline jzagaja  Poland
2 cu. ft. for 12BR70 with good results vs. 5 cu. ft. for 12B100R is huge difference
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 17th October 2012, 07:35 PM   #23
Impedance with and without notch.
Old 17th October 2012, 10:20 PM   #24
Dissi is offline Dissi  Switzerland
Proper bass reflex function can seriously be affected by two factors:
1. Interaction with some types of passive crossover filters
2. Standing waves in tube-like enclosures
Sorry Jzagaja, as long as you do not reveal any information on that, we are fishing in the dark.
Old 17th October 2012, 10:32 PM   #25
Tell me what would you like to know
Old 17th October 2012, 11:00 PM   #26
Best would be a diagram of the crossover (woofer section only) and a sketch/picture of the cabinet, but a description in words will do as well. I'm very surprised to see the left impedance peak rising due to the notch. Do you have an enclosure with a large dimension (1m or more)?
Old 18th October 2012, 05:48 AM   #27
Take a look.
Old 18th October 2012, 10:35 AM   #28
The enclosure looks nice. It's thin and long and is actually a tapered quarter wave tube (TQWT). For that reason the results are different from a classic bass reflex box and you do not have enough kickbass. The calculation of a TQWT is very difficult, I can not do that.
Old 18th October 2012, 08:22 PM   #29
VaNarn is offline VaNarn  Australia
It's a commercial design to sell on looks rather than giving optimal sound.I would completely fill it up with Tontine or other suitable stuffing,if that has not been done already.The notch filter is what it was said to be and not impedance correction as I had assumed.It is possibly there to alleviate a strong column resonance and my thought is that this type of problem is better dealt with by elimination at its' source rather than a secondary 'cure'.
Old 18th October 2012, 08:25 PM   #30
The idea behind Mummy was to have universal case so that anyone can try waveguide with his/her favorite woofer and driver. With 12BR70 it works great. With 12B100R a bit shy.
Impedance Bass Reflex - check up Beyma 12B100RHide this!Advertise here!
Bass Reflex Enclosure for Beyma 10BR60 -_nando-_ Multi-Way 7 22nd June 2013 01:25 PM
:) Check my first Bass Reflex 6 ports, 2 driver standard configuration design :) endrek Subwoofers 31 11th April 2011 05:37 PM
Bass reflex box for Beyma 8ag/n bubuxxl Full Range 29 21st October 2010 12:20 PM
Best bass out of Beyma 18 p1000 ??? slacker0001 Multi-Way 1 13th July 2005 03:38 PM
bass reflex? GAK Multi-Way 2 23rd October 2001 03:04 AM
Copyright ©1999-2017 diyAudio
