Old 30th October 2003, 05:20 PM   #1
Atom66 is offline Atom66  Canada
Default Ribbon Tweeter
Hi
Can anyone tell me anything about this ribbon tweeter.I have some that I would like to use in a line source.
Andrew
Old 31st October 2003, 12:43 AM   #2
What ribbon were you thinking about using?
Grey
Old 31st October 2003, 12:43 AM   #3
Bose(o) is offline Bose(o)  Canada
Which ribbon tweeter?
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 31st October 2003, 01:01 AM   #4
diyAudio Senior Member
fdegrove's Avatar
Default TIE A YELLOW RIBBON 'ROUND THAT OLD OAK TREE...
It sure looks good.
Ta,
Frank
Old 31st October 2003, 03:11 AM   #5
mcp is offline mcp  United States
Default PYLE RIBBONS
I have a couple of Pyle's aluminum ribbons that I believe were originally meant for car use. Looks the same as yours Andrew.
Michael Chua
Old 31st October 2003, 06:32 AM   #6
kiwi_abroad's Avatar
They also look exactly like my Tonigen ribbon tweeters. They havn't been made for quite some time, and I have no information on them, except they are a quite low impedance (Down to 2ohms) and their lower cutoff frequency is around 6kHz.
Old 31st October 2003, 06:48 AM   #7
Andypairo's Avatar
On Ebay there are some similar models, the most "look alike" are the Multicel and JVC models.
However no technical data available, AFAIK.
Those should be crossed at a frequency greater than 5-6k, making a 3-way speaker mandatory.
If you want to make a 2 way you need to choose a different driver.
Cheers
Andre
Old 31st October 2003, 10:21 AM   #8
fdegrove's Avatar
This is the ribbon tweeter I'm using in a 3-way system but you can just as well put it to good service in a 2-way.
VISATON MHT12
The price is 156,24 Euro from Visaton.
Frank
Old 31st October 2003, 12:58 PM   #9
Thanks everyone for your help.I bought a box of these drivers from a Radio Shack clearance centre a couple of years ago and have never been able to find any info on them at all.Now I have enough info to at least start looking at using these drivers .I am thinking of using them with some Carver 60 " ribbons in a dipole configuration.
Andrew
Old 3rd November 2003, 04:02 PM   #10
MarkMcK is offline MarkMcK  United States
Default JVC branded Ribbon Tweeter Measurements
Andrew,
Sorry for the delay in making this post, but I am just not a fast responder. I thought you might like some measurement data to help you design your crossover. I have attached a gif file of the impulse and frequency response of the JVC labeled version of this driver.
I am sorry that this driver is no longer being manufactured. It performs better than many current dome tweeters. It is stable over time. Mine have not changed in over twenty years. I first used this tweeter in a three-way loudspeaker in the early eighties. I used a 10-inch MFB woofer crossing to a 50 mm Jordan module at 400 Hz, crossing over to the ribbon tweeter at 12 kHz. While the foam surround on the woofers and the polymer doped spiders on the Jordan modules have turned to dust, and the doped cloth surround on the Jordan modules have hardened into immobility, the ribbons continue to perform as if they were new.
This driver also performs just as well (maybe better) as the newest batch of affordable ribbons currently on the market. The driver is not perfect, but I have always found its sound to be pleasurable. Like all other ribbons, its vertical dispersion is narrow and most of the output below 8 kHz is from the resonant decay structure of the diaphragm.
I hope your design works out and you can enjoy the sound of this ribbon driver.
Mark
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 04:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
Ribbon Tweeter jerryo Planars & Exotics 2 26th August 2008 05:09 PM
Looking ATD le ribbon tweeter sma Multi-Way 0 23rd November 2004 11:31 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 07:21 PM
Page generated in 0.09627 seconds (79.53% PHP - 20.47% MySQL) with 11 queries
