#911 | |
frugal-phile(tm)
Here is an example (with a 2" driver in a 4" pipe it wasn't a big issue, it starts impinging with the 3" scan now in the pipe, and that will have more clearance than the pipe pictured above.) ![]() dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#912 |
Example of what impinging where with 2" driver v 3" driver in relation to question being answered regarding early reflections at rear of driver diaphragm at vocal formant frequencies in particular?
#913 |
Those pipes look rather short to avoid longitudinal reflection/resonances (which is what I suspect you are hearing). But in any case frequency response curves (which should show the ripple, wherever it is) would tell a lot more. Not to be too glib about it, but I don't see any evidence of lateral reflections in the pictures . . .
#914 | |
frugal-phile(tm)
dave
#915 |
Hard to do in that short a pipe.
I haven't heard "cuppiness" in any of the PLUTOs or PLUTO clones I've heard (including my own). Can't figure why your implementation as shown would have lateral reflections while none of the others do. |
#916 |
Magic, same design in one case incurs significant trade off, and in other design works just fine.
Aperiodic tuning must be complete only after "Cuppiness" is tweaked out by ear? What is good test setup for demonstrating "Cuppiness" that my ears may learn to hear something that can't be measured? Regards, Andrew |
#917 | |
frugal-phile(tm)
It is well accepted that 10,000 hrs of serious training are required to become really good at any endeavour. dave
#918 |
Bunk.
#919 | |
frugal-phile(tm)
![]() That you would say that says alot... Quote:
#920 |
| Active or Passive | bjackson | Multi-Way | 30 | 4th April 2005 10:49 PM |
| Passive into active | MethMan | Multi-Way | 8 | 12th January 2005 04:58 PM |
| Active of passive | audiobomber | Multi-Way | 9 | 31st July 2004 02:31 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
