Active vrs passive
Active vrs passive
Old 24th December 2012, 03:35 PM   #891
twest820 is offline twest820
Originally Posted by CopperTop View Post
Isn't a multiway speaker always going to constitute two or more sound sources with different directionality characteristics, whose drivers are individually 'phase processed' by the room, and mixed acoustically i.e. artificial phase trickery?
To some degree, yes, but consistent directivity can be prioritized among the various speaker design tradeoffs if one wishes. In particular it's hard to acheive consistency between vertical and horizontal directivity in a point source speaker which achieves commercially viable SPLs. Line arrays solve this but tend to be too big for home audio, which leads to problems with phase coherency as the walls and listener are acoustically close. Making the room dead can address that, but such extensive room treatment is often not feasible. In a lot of ways it works better to chuck the whole problem and go with IEMs but one advantage DIY has here is that, since you're not usually trying to make a buck off the speakers, you can relax the SPL requirements in favor of improving directivity. When I did that I ended up here. Not really any rules of thumb in that design; it was all simulated beforehand and there was as much of a chain of ABX test results behind the design decisions as I could manage (though some things, like testing of different speakers, are really hard to make wholly blind in a home context).
For commercial builds where the design process is openly available try Geddes and Nao, both proprietors of which are active on this forum. In addition to the usually cited sources you might also find the papers from Harmon-Kardan's research group interesting. In DIY, the Ardor springs to mind as well, as do some of the builds from the moderators over at the misson possible forum on HTGuide. At the end of it, planet10 is right, though; there's enough we don't really understand about hearing and how listener to listener variation affects subjective sound quality that, at the end of it, as a designer you have to pick some tradeoffs, build something, and see how it turns out.
I would, however, argue that most performance is entirely predictable from physics based reasoning about a design. The main difficulties is the metrics needed to translate that into a prediction of subjective quality don't exist and that their establishment is beyond the resources of nearly all DIYers. So what you see in this forum is a lot of people either struggling with the learning curve to understand audio---the physics are not easy and neither is psychoacoustics---or struggling to figure out why something does or does not works well for them. Sure, it's messy. Get used to it.
Old 24th December 2012, 03:39 PM   #892
Barleywater is offline Barleywater  United States
I like it. What do you define as a low slope? Anything below 16th order, say?
Presumably with steep crossover slopes there is less reason to use it anyway..?
Transition from ripple to dip is seen in pic with 4th order. Ripple is lobe behavior. Dip is smooth wavefront.
I see no reason to compromise on axis performance for off axis performance.
I see greatest advantage of steep slopes in controlling IMD.
Andrew
Old 24th December 2012, 03:45 PM   #893
CopperTop is offline CopperTop  United Kingdom
Just to clarify: you would define 4th order as steep or shallow? What slope do you tend to use in your own speakers?
Old 24th December 2012, 04:03 PM   #894
Do you have an opinion on the so-called Stochastic Interleave function described here?
I'm not Barleywater, but interesting paper. I'd expect the interleave to sound worse; the transition band is wider and less consistent whereas all the test results I've gotten favour narrowing the band and keeping the bounding volume of the radiating surface as acoustically small as is feasible (at the crossover's center frequency the radiating surface is obviously the union of both drivers but there's no well defined point in an XO's stopband where the suppressed driver is no longer audible, though I would tend to say it 40 to 60dB down is a reasonable choice). However, ya don't know for sure until you set it up both ways and ABX it. Fortunately digital makes ABXing a lot easier.
Old 24th December 2012, 04:32 PM   #895
But how narrow would you make the band? Some people think that steep filters sound intrinsically worse because of pre-ringing, and/or that a generous degree of overlap is naturally a good thing so that there is a less abrupt transition between drivers. Personally, I think you can go pretty steep without a problem, but maybe my ears aren't golden enough.
Old 24th December 2012, 05:21 PM   #896
Pano is offline Pano  United States
Pano's Avatar
Active vrs passive
Can you give an example of something you have done that lifted a speaker beyond average?
A few examples might be:
  • Where do you set the crossover frequency and why? Standard practice or your own findings and choices?
  • Steep filters, shallow or a mix? How much overlap or spread?
  • Driver placement and alignment. A pretty, symmetrical layout, or something more researched and refined?
  • Harmonics. Do the drivers have similar harmonic signatures, or ones that work well together?
  • Is your crossover point good harmonically for your drivers? Or does it sound strange? This can be counter-intuitive.
  • Driver Q. Are they similar? If they are, the drivers tend to blend better and call less attention to themselves.
  • Box tuning. By the book tuning, or something you find works better? It's surprising what works and doesn't with boxes.
  • System Q. Optimally damped or over/under damped? Which do you prefer? Which works best with the other limitations of the speaker?
  • On and off axis, or power response. What's important to you? How will the speaker be used?
There are standard approaches to speaker building that will get you a long way on the path to a good speaker. You won't go wrong with them, but you might not end up with a speaker you really love, because the standard approaches don't take into account the myriad choices and trade-offs you need to do. You need to listen, measure, think, choose, and listen more.
The problem with speakers is that we have to listen to them.
They would be much easier to design if we didn't.
Take the Speaker Voltage Test!
Old 24th December 2012, 05:42 PM   #897
Causal filters do not prering but linear phase filters do, so the tradeoff depends in part on how much phase error you're willing to accept and whether the speaker you're building allows you to rake the drivers to compensate (works in boxes, not so much with open baffle). There are few single variable optimizations in audio and crossover selection tends to be one of the more multivariable ones since driver behaviour, box/baffle/nude driver directivity, and room response are involved in addition to the cleanliness of the crossover's impulse response and the acoustic size of the variation in the radiating surface. A good exercise is to set up a digital XO and spend an afternoon measuring and auditioning different crossover alignments and phase corrections.
Personally it's my experience it's not exactly easy to beat a fullranger with a multiway design especially at a comparable price point, though digital helps a lot there and I seem to be more fussy about a tight impulse response than average. I've yet to hear an odd order alignment where the quadrature sounded as tight in a linear phase crossover as the in phase summation of a Linkwitz-Riley alignment. I can't see myself ever using less than LR4 in multiway---I agree with the benefits claimed for shallower slopes but the better directivity control and avoidance of driver limitations (such as cone breakup or Bl nonlinearity) of LR4 has consistently been subjectively preferable for me (expect a bunch of posts disagreeing with this, though passive LR4 is certainly a pain)---but every time I've tried it LR8 hasn't sounded quite as good. Not entirely sure why; maybe it moves the sound location too rapidly in frequency, maybe it's greater preringing when corrected to linear phase, though I would tend to bet more on the transition being too fast. B5 and B7 (fifth and seventh order Butterworth) have that odd order offness to me, whether linear or warped phase, so I haven't used them even though a lot of people like odd order crosses. As a result, my go to crossovers are LR4 and LR6. Of the two LR6 usually sounds a bit better, mostly because I can pull the mid-tweeter cross a bit lower and get slighly more controlled directivity out of it. Though sometimes it's helpful in working around driver limitations.
I've not tried ninth order or higher...
Old 24th December 2012, 05:54 PM   #898
Pano's Avatar
Active vrs passive
Amen! But it takes me longer than an afternoon.
FWIW, I also like LR 4th (or Bessel) and will use whatever electrical function it takes to get that acoustic slope. For me, it's often 3rd order electrical.
Old 24th December 2012, 07:24 PM   #899
I wish I could be so certain about what sounds best when auditioning! In my homebrew software the aim has been to make it as real time as possible. I can calculate and load new filters on-the-fly, and modifying delay, crossover point or filter slope is done by changing a single value so I really can do an A/B test very easily. I also have facilities to instantaneously switch baffle step compensation in and out, and amplitude & phase corrections based on measurement. The stochastic interleave function is next on the list.
But I can't tell you what sounds 'best'. I can tell you which grossly maladjusted settings sound bad, and I can hear subtle differences on white noise, but there is a broad range of settings that make little audible difference, or do not clearly show up as better or worse than other settings. Or are matched in significance by changes in listening position. I suspect that moving objects around in the room would also be significant. But then, how do I know that a 'good' setting isn't just a one-off for the particular types of music I've tried it on? All I can say is that the broad range of settings which don't change the sound particularly, in fact sound extremely good.
The one moment when I've gone "Wow!" has been when applying what I thought was erroneous phase modification. I was convinced my code was applying twice as much phase correction as required (based on mid and tweeter individual measurements), but having the time to sit down with it today, I see that it isn't... How wonderful it would be if I was hearing the effects of correct phase compensation through the crossover region, and that in those circumstances I could tell that a shallower crossover sounded better than a very steep one...
Old 24th December 2012, 07:30 PM   #900
Charles Darwin is offline Charles Darwin  United Kingdom
If I choose all my drivers so that their response extents flat past my crossover point by an octave or two can I then assume that electrical slope = acoustic slope?
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright ©1999-2017 diyAudio
