Active vrs passive
Active vrs passive
Old 10th December 2012, 07:04 PM   #861
john k... is offline john k...  United States
john k...'s Avatar
Originally Posted by dewardh View Post
This is a possible (theoretical) advantage of series over parallel passive crossover topologies, but with active the amplifier does the same thing even better . . . it "washes out" the effect of the dynamic changes in driver behavior. I'm not convinced that it makes a whole lot of difference, but the immunity from driver effects, dynamic and otherwise, that the intervening amplifier provides is one of the arguments for an active design.
Actually, actives do not wash out dynamic effects. Just another myth. I know a lot of people say that but it is simply not true. What actives do is keep the voltage transfer function constant. That sounds like a big deal but it is current, not voltage, the generates the force applied to the cone. So as the voice coil undergoes dynamic changes in impedance the current and resulting force applied to the cone still vary even though the voltage transfer function remails fixed. If you want to wash out dynamic changes in driver behavior you have to go to current drive.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 10th December 2012, 07:04 PM   #862
Pano is offline Pano  United States
Pano's Avatar
Active vrs passive
Please do not quote the entire post just above yours. Over-quoting cleaned up.
Old 10th December 2012, 07:08 PM   #863
ORNJ is offline ORNJ  United States
It's just double (3dB) . . . which is pretty much enough to account for crest factor and (passive) crossover losses (in a reasonably designed system). Some people will argue that the passive systems needs even more power, but I think that perhaps they exaggerate . . .
Oh yea, but I was thinking more in terms of draw from the wall though....I like saving a buck anywhere possible.
Old 10th December 2012, 07:08 PM   #864
dewardh is offline dewardh  United States
Originally Posted by Barleywater View Post
A parallel or series circuit of linear components has linear transfer function at every node.
Parallel and series crossovers, however, have different nodes, and different resulting properties.
Old 10th December 2012, 07:09 PM   #865
john k...'s Avatar
Originally Posted by ORNJ View Post
I am sure that this has been mentioned before on here but I feel that Linkwitz's explanation of why active is better makes perfect sense..
The amplifier has more control over the driver and you can implement different types of crossovers for the best possible sound.
Again, the argument is flawed. What controls the driver is the current through the voice coil. It makes absolutely no different how that current gets there, directly from the amplifier's terminals or through a passive crossover. The only difference between active and passive is that with an active crossover the voltage transfer function is not affected by any variations in driver impedance.
Old 10th December 2012, 07:13 PM   #866
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Active vrs passive
But when the values of the driver change, so does the transfer function. In a series XO things move such that things hang together, because everything affects everything. In a parallel circuit, HP & LP are independent.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th December 2012, 07:19 PM   #867
Barleywater is offline Barleywater  United States
The linear components can only apply linear change.
As JohnK points out, current drive, which is really just current feedback, in active system that can and does dynamically respond to changing reactance
of driver.
Andrew
Old 10th December 2012, 07:23 PM   #868
Originally Posted by john k... View Post
The only difference between active and passive is that with an active crossover the voltage transferfunction is not affected by any variations in driver impedance.
That's not a trivial difference, and it's maybe not the only one. Depending on how you choose to look at it (perspective) the increased source impedance (caused by series resistance in the passive crossover) does change driver behavior (the higher the source impedance the more it behaves like current drive). There are even books on the subject . that claim current drive reduces distortion. I haven't been able to measure it, but the theory's there . . .
Old 10th December 2012, 07:38 PM   #869
john k...'s Avatar
Hi Deward. I didn't say it was a trivial difference, but that the voltage TF doesn't change does not mean dynamic changes in the driver's impedance are washed out. That is the point that is missed.
I do agree that this is mostly a theoretical argument. both passive annd active speakers, parallel or series, can sound very good, or bad. It's more about good design than one or the other.
Old 11th December 2012, 04:47 PM   #870
I'm sure that's probably true . . .
I've just gotten so in the habit of thinking of "drivers" as having a constant Zin (of about 10k resistive) and equal sensitivity that I sometimes forget the "old ways" . . . (actually I still sometimes use "passive" shaping circuits thrown in there somewhere to adjust the response, sort of like SL did between the mids).
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
