Active vrs passive - Page 85 - diyAudio
Old 4th December 2012, 09:00 AM   #841
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Telstar View Post
I'll see if i can make it work, but I have some doubts
could be its a different matter with fullrange drivers
Old 4th December 2012, 09:06 AM   #842
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Multibit ofc, but the filter F3 (1st order) was too low, I think if that such filter is cornered at 200 or 300khz won't be as harmful (i.e. the classic veil on the sound), but I couldnt experiment that. I can do the same thing at amplifier input*, but I'm not ready to develop the amp yet.
My experience is quite the opposite - best with fairly steep band limiting. I'm listening to an elliptic band-limiting filter at the output of my DAC right now. So far the best sound I've got out of this DAC - the elliptic just replaced a 4th order Burtterworth (the current one is 7th order, 17kHz cut off, -50dB by 22k).
Mind you, I dont agree with Lavry's papers. They work only for sigma-delta DACs which he makes.
Use also your ears to judge. I mean this, as some wise man said, "if it mesures bad, it's bad, if it measures good AND sounds good, it's good".
Lavry makes multibit too. I agree that ears are the arbiter, not meters but 'measures bad' is highly context dependent.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 4th December 2012, 09:11 AM   #843
Telstar is offline Telstar  Italy
Ouch! no treeble.
Between drilling treeble and attenuation I would also choose the latter (and i did with the FR), but with a good dac and speakers it shouldnt be needed. I'm afraid something is wrong in your chain.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 4th December 2012, 09:15 AM   #844
abraxalito's Avatar
I tried a siggen through my speakers - I can't hear anything above 15kHz for sure, so 17kHz is generous. Plenty of sparkle in the top, I'm a very happy bunny with the results. Soundstage grew quite a bit too on changing the filter - the rear extension of it was quite a big surprise to me.
Old 4th December 2012, 09:25 AM   #845
The real problem with early lowpass filters is the phase change in the middle of the audio band. I guess that your 7th order @17khz would be more or less equal to a 4th order at 30khz, or better so not that bad in the audio band (but i suck at math so probably i'm wrong ).
Yes, this explains why it sounds good to you.
I didnt dislike much the old brickwall filters and digital is now allowing us to play with very steep filters without much degradation... but I'm still afraid of anything higher than 4th order with passive components.
Old 4th December 2012, 09:35 AM   #846
abraxalito's Avatar
Ha you need to be careful in judging the phase performance from just the order - this is an elliptic, the group delay plot looks fairly benign (30uS or so) up until 14kHz where its doubled (60uS) and after that it goes totally ballistic, reaching over 250uS at the cut off. So you think I enjoy this kind of phase distortion? How does phase distortion improve the soundstage do you think?
Old 4th December 2012, 09:43 AM   #847
Yes you either enjoy it or you don't hear it. Personally, I think the human ear is NOT very sensitive to phase shifts, especially if they are linear.
Old 4th December 2012, 10:15 AM   #848
Hard to do AB if you have to solder/desolder even one part to change a frequency.
I'm looking to do something along the lines of Pass XVR1/B4 or Bryston 10B.
Strangely there isnt any diy projects of such sort. There is plenty with fixed frequencies.
D.Self did an active crossover with adjustable frequencies way back in the 80's.
This Forum ran a few Threads on adjustable crossovers. There were 3 or 4 different versions on their own PCBs. Read Mox.
These can all be done as plug and play.
A case with the plug board facing the bottom could be very quickly changed by removed the protective cover and swapping a DIP plug with the new frequency components. Or use DIP switches.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th December 2012, 10:34 AM   #849
No problem at all since the components which determine frequency and slope are on little plug-in cards and I have a few spare ones.
I can change and A/B in a matter of seconds.
Old 10th December 2012, 08:58 AM   #850
Default Stochastic interleave crossover-filter alignment
Just came across this variation on active crossovers. I don't know whether it works as advertised, but if it did, it might be something worthwhile that passive crossovers simply can't do. Has anyone tried this? (Unintentionally, I may have done something very similar in one experiment, and it sounded good, but I realised my 'mistake' and 'corrected' it...)
Because in the principal crossover region at least two drive units are radiating significant energy, then interference will occur especially when the path lengths change as a function of angle as is the case with non-coincident drivers. In this Section, the incorporation of a static random vector in the crossover filter response is explored as a means of reducing the subjective significance of polar response errors. This random sequence together with selected frequency shaping is termed the interleave function.
A design requirement of a crossover filter is that the loudspeaker should have a well-behaved off-axis frequency response. This is normally described in terms of the polar distribution which is influenced both by the frequency dependent spatial characteristics of a drive unit, the physical spacing of the drive units and the baffle size and profile. The frequency region in which the crossover has influence is defined in terms of the filters' attenuation characteristics together with their relative phase response. The effect of non-coincident drive units is to introduce a time delay between the soundfield radiated from each drive unit. This in turn can be represented by a frequency dependent phase difference, which creates interference.
To implement a stochastic crossover alignment a zero-mean random vector rd(n) is generated that consist of a unit vector with superimposed noise sequence. An overall weighting factor L is included to set the noise level together with an option for bandlimiting the noise spectrum formed by the destructive envelope bound of, for example, a prototype linear-phase Butterworth filters.
The effect of this process is to leave the composite response unmodified but the difference response, that determines the off-axis lower interference bound, is noise like. Consequently, inter-drive unit interference that occurs in the filter transition band is distributed more broadly with narrow bands of constructive and destructive interference. An example stochastic interleave crossover is shown in Figure 5-1, while in Figure 5-2 four off axis composite plots are shown with a progressive increase in time delay between drive units. Complementary randomization in both the high-pass and low-pass filters should be observed together with the destructive envelope. It is conjectured that with music signals or any non-periodic signal which must have a broader spectrum, that there are beneficial effects to be gained from this randomization especially as the micro-structure of the interference varies with angle and is not localised to a discrete frequency null. In this sense, a similarity with a distributed mode loudspeaker (DML) should be observed [NXT White paper, 1996]. Finally, it should be noted that the proposed noise additions are static and consequently the resulting changes in frequency response are also static and do not result in actual noise signals.
http://www.essex.ac.uk/csee/research...alignments.pdf
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright 1999-2017 diyAudio
