#791 |
flavio, analogue active is the direction im more comfortable following. DSP is touted as a panacea for all ills. With passive and analogue, I at least know what colourations to expect, and so does my ear. The ear ignores many flaws but pre-ring is a concern with convolution. Its not a natural distortion, and the ear will detect it easier than other distortions, though at what level is subject to debate.
It still amazes me every time I get something right |
#792 | |
Going beyond 4th order passive is plagued by reactive behavior of drivers and insertion loss. Going beyond 4th order analog active begins to push realistic demands for component matching to obtain targeted filter responses. Regards, Andrew |
#793 | |
A proper inverse for minimum phase response may be transformed into a minimum phase filter, with zero pre-ringing. Convolution with basis IR results in flat spectrum, but resultant IR is minimum phase replete with group delay and associated phase behavior. Audibility of steep crossover linear phase filter is virtually identical to high order minimum phase filter. Acoustic centers distance v crossover frequency is the culprit impacting off axis behavior. Poor design choices lead to poor results. Yes, auditioning a steep crossover filter by solo listening to its IR may present as horrible ringing, but this is out of context of filter applied to continuous time signal; and with its conjugate also operating. This is not debate or vague regurgitation of others work, but my results from hundreds of hours experimentation based on academic study. As Coppertop has found, and many others too, initial results with most software packages tend to be awful, but tends to stem from poor measurement technique, and to gaining understanding of software control parameters. Regards, Andrew |
#794 | |
Test stimulus is band pass 1.5kHz-1.7kHz burst: BP1k5-1k7 120v p-p Peerless 830970 2inch.gif 2nd harmonic comes in at about 2.5% using signal that has 120v p-p maximum. I come up with instantaneous power of about 450watts. The stapedius and trigeminal muscles don't finish contracting until after burst, causing room sound to momentarily dim. Wine glasses at 5 meters ring. When abuse is repeated with burst centered at 6kHz, 2nd harmonic drops to about 0.5% Both bursts are summed, 120v p-p maximal signal applied and nice display of intermodulation distortion results: BP1k5-1k5 with BP5k8-6k2 IMD.gif Under controlled bandwidth conditions, driver exhibits order of magnitude cleaner performance than compression drivers. Regards, Andrew |
#795 |
Thanks for the tests. Nice little drivers. I don't think I'd call them tweeters, exactly, but they could be used that way. I have a pair of the Vifa TC9FD18-08 3.5" FR that also serve well as big tweeters. I would not try to run them long at 450W, but they are more rugged than the typical dome tweeter.
![]() And speaking of rugged dome tweeters, I've run the ScanSpeak 3806 for years and really like it. It's the Mack Truck of dome tweeters, but gets the job done. Matches very well with most 12" woofers. Some call it a mid-tweet, which might be more accurate. A great driver. |
#796 | |
Could you explain how you arrive at an instantaneous power of about 450 watts from a signal that has 120v p-p maximum? How was the 120v p-p maximum measured? What is the SPL of the above test? Could you post an exhibit of a compression driver at the same SPL and the resultant distortion? Art |
#797 |
nice tests, seems those small wideband drivers arent bad at all. On the topic of the thread I have come up with the simplest active solution that i can try. Using a GEQ3102 and the variable butterworth 2nd order low cut 10-400hz for widerange driver filter, and an additional subwoofer amp module. Trouble is finding such an amp with a similar range of turnover frequencies and slope. Once im paid it may be worth a shot.
Any suggestions for the sub amp? Andrew I follow most of which you speak, and I do not diasgee. The problem for me is that I do not wish to spend the same length of time as you have, in order to eliminate preringing in my home stereo. Is all of that possible to the layman, without a doctorate? If so then great, if not then id rather stick to the evils i understand and can tackle, rather than implement a DSP solution which may be beyond My capability to resolve to my satisfaction.
It still amazes me every time I get something right Last edited by mondogenerator; 18th November 2012 at 12:52 PM. |
#798 | ||
Take the Speaker Voltage Test! |
#800 | |
BP1k5-1k7 120v p-p Peerless 830970 terminals.gif BP5k8-6k2 -3db4 terminals.gif Above pictures are of recorded terminal voltages. Some details: Square driver flange is milled round for mounting into end of 2" ID PVC pipe that is 12" long. Pipe is stuffed with Dacron, and other end is left open. Calibration is accomplished by playing 60Hz sine with amplifier (Hafler Pro2400 running bridged) output unloaded and adjusting output level with voltmeter to reading of 44.7v RMS via volume pot of E-MU 0404 USB. This is peak voltage +/- 63.2v. Fostex FR-2 is used for capture. Hot and cold phases are connected across output of amplifier at end of speaker wire with 44.7v RMS signal, and FR-2 input attenuator is adjusted for signal peak of -3.0dB. This is monitored in DAW software, Sonar LE, by connecting FR-2 digital out to E-MU 0404 USB soundcard. In previous similar studies a DC coupled and calibrated oscilloscope was used in conjunction with above methods and equipment for validation purposes. From recorded terminal voltage peaks (+/-) at center of waveform, -3.4dB is seen, corresponding to +/- 60.37 volts. Extrapolating this as true sine, this is divided by 2^0.5 for RMS voltage of 42.69 volts. Squaring this and dividing by 4ohms yields power of 456 watts. In reviewing calculation, 4 ohms is underestimate of driver impedance at 1.6kHz and at 6.0kHz. Working from impedance plot in manufacture driver specifications, these are better taken as 4.7ohm and 6.0ohms respectively, yielding a mere 388watts for 1.6kHz bursts, and 304watts for 6kHz bursts. For combined signal burst, power bandwidth is split roughly in half (-6dB)to each of the signal bands. If I had 1kw amplifier kicking around, I'd try it. I did not reference acoustic response for 1watt input, but driver specification is 82dB/1watt. This is horrible compromise made for size, cost, and intended applications. Nonetheless, at 388 watts this is 2^8.6 over 1watt or 6dB x 8.6 + 82db = 133dB estimated SPL. Throw in a little tiny bit of power compression and peak SPL is still likely very high. Normally I run this driver crossed at 1kHz with Hafler Pro1200 in stereo mode. Amplifier is conservatively rated, and rail voltages are relatively high for spec. Transformer, power caps, and 1 pair output mosfets limit, but for my application provide nice headroom for transients. I like symphonic music where each instrument sounds live. Full orchestra peaks are known to be 100-110dB at conductor's position. Uncompressed recordings are awesome. I don't own any compression drivers, but have down loaded mp3 results from your previously posted links, and what I see is not impressive for domestic settings/critical listening, and is stock and trade performance for PA sound. I will happily upload burst stimuli of requested band widths for anybody interested in running tests similar to these. All flavors of format are possible, excluding 64bit stuff, which is completely unnecessary. My above posts are preamble in continuing with topic: Active v Passive. The above methods are employed. High pass crossover performance is analyzed starting with brick wall low pass filter set to intended corner frequency of high pass filter being studied. Peerless 830790 is billed as full range driver. High powered testing as above indicates driver is relatively immune to failure under adverse conditions, and 1kHz 24k point FFT low pass filter (LP1kFIR24k) bursts didn’t destroy or otherwise appear to harm it even with maximal signal. In this case function follows windowed sync filter and single cycle maximal voltage swings from –13v to 60v. Frequency response below 1kHz appears much as swept sine results with small signal, but above 1kHz a large output is seen: Peerless 830970 LP1kFIR24k 60v peak zoom.gif Above picture of test spectrum and of result spectrum both are 1kHz referenced to –6dB. Clearly the driver is not able to handle signal without lots of distortion. Next results show band passed burst 430Hz to 1kHz with 24k point FFT filter (BP430-1kFIR24k) also with 1kHz referenced to –6dB: Peerless 830970 BP430-1kFIR24k.gif Performance is greatly improved, but stop band <430Hz and >1kHz rides in –36dB zone. This isn’t noise floor, but sea of distortion components as sums and differences of fundamentals and their harmonics. Noise floor is effectively around –72dB. The maximal voltage swing is –46v to 60v. Sound is short, loud, and produces sensation similar to slapping palm of hand against ear. Ouch. ![]() Above results set groundwork for investigating performance of 1kHz high pass crossover filters. ....Which will follow shortly. Last edited by Barleywater; 18th November 2012 at 04:54 PM. Reason: typo |
| Active or Passive | bjackson | Multi-Way | 30 | 4th April 2005 10:49 PM |
| Passive into active | MethMan | Multi-Way | 8 | 12th January 2005 04:58 PM |
| Active of passive | audiobomber | Multi-Way | 9 | 31st July 2004 02:31 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
