Active vrs passive - Page 75 - diyAudio
Old 10th November 2012, 01:51 AM   #741
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by Charles Darwin View Post
I wonder how many dome tweeters stay below those THD levels when you feed them the 100-200W necessary to reach those SPL levels.
Most of them, I'm sure. After a brief flash and puff of smoke, of course!
Old 10th November 2012, 02:41 AM   #742
5th element's Avatar
If they are within xmax and the average power delivered is low enough so that they don't fry, it'll be reasonably low. Dome tweeters do fairly well with high SPLs as do most hifi drivers, the trouble comes when they are expected to keep it up for extended periods of time, then things melt.
There are some examples here
Zaph|Audio - Design Contest Results
Old 10th November 2012, 08:07 AM   #743
mondogenerator's Avatar
Flavio and deward. You guys know the digital domain. Passives arent obsolete '78 tech, and you both know that too. It is merely the origin of all filter topology. How do you filter the input to ADC? Passively. Many passives used in DSP too, prior to digi filters.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th November 2012, 11:25 AM   #744
Originally Posted by Pano View Post
.............Very steep filters, ..................fail to convince me sonically. ........
what do you mean by very steep?
3, 4 & 5pole or 8pole to 18pole?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th November 2012, 11:29 AM   #745
Originally Posted by AndrewT View Post
Why?
a 110dB compression driver with a 10mW signal is comparable in output level to a 90dB cone driver with 1W. Both will give ~90dB SPL @ 1m
Originally Posted by Barleywater View Post
high loudness studio monitors = deaf engineer = poor mix.
Please show me something better than results in High Frequency Compression Driver Evaluation thread:
These are post 1980 drivers. 4%-10% 2nd harmonic is not natural or reasonable for high fidelity, and whatever a "pure amplifier" is, it's not going to fix this.
What is mechanism for "pure" amplifiers elimination of driver distortion?
Andrew
I asked and you gave this?
02dsHi+6 108.4 dB, 4% 2ndHD
Does that answer?
I don't even know what that is telling me.
regards Andrew T.
Old 10th November 2012, 12:15 PM   #746
Today's my day to go active with my JBL cinema speakers (4622). I bought three Crown DSi 1000's. These have the preset crossovers for my speakers. Can't wait to see what improvements I get vs. passive.
Old 10th November 2012, 12:20 PM   #747
I can guarantee at least one result:
It will sound very different from using one amplifier with all three drivers attached in parallel across the amps output terminals.
regards Andrew T.
Old 10th November 2012, 12:40 PM   #748
Does that answer?
It is line from results post showing 2nd harmonic of 4% when output is 108dB for a particular compression driver. It is an excellent predictor that IMD products from driver when fed two tone stimulus will be audible as well the 2nd harmonic. Loud yes, high fidelity, not in my opinion.
Andrew
Old 10th November 2012, 12:51 PM   #749
02dsHi+6
is a compression driver description.
and is there a comparable result for a cone driver to show us?
regards Andrew T.
Old 10th November 2012, 01:14 PM   #750
Pano's Avatar
Mostly I mean near brick wall, the kind that are only practical in DSP. But generally most above 6th order electrical.
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright 1999-2017 diyAudio
