Active vrs passive - Page 64 - diyAudio
Old 30th October 2012, 10:30 PM   #631
Pano is offline Pano  United States
Pano's Avatar
Here it is, Altec Technical Letter #237
http://alteclansingunofficial.nlenet...ers/TL_237.pdf
Note what is said in the second paragraph
Old 30th October 2012, 10:36 PM   #632
frugal-phile(tm)
planet10's Avatar
Originally Posted by Charles Darwin View Post
Watching movies is fine but the ads in the breaks are very heavily compressed so that the rms level is much higher than the movie soundtrack
Now (or soon) against the law to do that in Canada.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th October 2012, 10:46 PM   #633
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
When I watched Eureka sci-fi soup opera I had to lower down sometimes -3 db from season to season. They were obviously changing compression ratio.
The Devil is not so terrible as his math model is!
Old 30th October 2012, 11:19 PM   #634
krivium is offline krivium  France
Thanks Pano!
Great informations, i think i understand difference between dispersion pattern and off axis response now.
Old 30th October 2012, 11:45 PM   #635
Speakerholic
Cal Weldon's Avatar
dave
CRTC tells broadcasting industry to turn down the volume on loud television commercials
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st October 2012, 02:48 AM   #636
Jay is offline Jay  Indonesia
Default ANALOG ACTIVE CROSSOVER UPDATE
I tried designing active crossovers with LTSpice this weekend, by simulating the circuit together with the potential amplifier circuits. While I can achieve good performance in AC analysis, FFT was horrible.
We usually work very hard to get a good performing amplifier. Now with the active crossover front end, the task is even harder!
Using analog active crossover is like running a good speaker with bad amplifier
Old 31st October 2012, 03:01 AM   #637
Brett's Avatar
^^ Show the results as well as the schematics you used. Also indicate what you thought about them was 'horrible'.
Old 31st October 2012, 03:52 AM   #638
puppet is offline puppet  United States
Pano ... that paper is pretty handy info. Thanks for posting it.
Old 31st October 2012, 06:09 AM   #639
"Horrible" means the low THD.
I tried 2 types of crossovers (Actually 3 but I quickly gave up using gyrator due to phase issues). Discrete and opamp based. For discrete I made a circuit based on Kaneda, but of course I used my own JFETs and BJTs. For opamp based I used 4 opamps per driver: 3 for Bainter Notch filter and 1 for LP/HP (It is perfect for outdoor system where THD is not critical).
For LP I aimed to use OPA111, for HP I used faster opamps where the faster the opamps the better the performance.
It is no secret. Just build an amplifier with opamp input and you will find in either simulation, measurement or listening test that the performance is a function of the opamp quality, and in my experience is far from top quality. And here we have to deal with more than one opamps...
Old 31st October 2012, 06:28 AM   #640
Brett's Avatar
Low distortion is bad? Bizarre.
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
