Active vrs passive Active vrs passive - Page 54 - diyAudio
Active vrs passive
Active vrs passive
Old 26th October 2012, 03:01 PM   #531
CopperTop is offline CopperTop  United Kingdom
Originally Posted by SY View Post
If there's a difference in the dynamic range/compression of my speakers before and after I went active, I sure couldn't hear it. And when I first got them, I will admit to cranking a few albums into the three figure SPLs...
In my case, I really think I can hear the difference - but it's not a blind test so I can't be sure. To me it manifests itself as a sense of the music pouring in through the open end of the room, compared to before where it was being 'forced' under pressure out of two boxes.
Old 26th October 2012, 03:08 PM   #532
Pano is offline Pano  United States
Pano's Avatar
Active vrs passive
You may well be hearing a real difference, and it may be the different crossovers. But I don't know if it's active vs passive. I have not noticed the effect going from active to passive, but admit I wasn't listening for it.
Old 26th October 2012, 03:11 PM   #533
puppet is offline puppet  United States
I believe that this has to do with where the signal is being processed .. in the low voltage line level stage vs the higher voltage speaker level stage. The position of the amplifier has to have an effect on driver(s) dynamics.
SY said he didn't hear any difference but I don't believe him :P
Old 26th October 2012, 03:12 PM   #534
Pano's Avatar
Active vrs passive
Originally Posted by abraxalito View Post
This effect does though have to be offset against the fact that IMD products outside the driver's passbands will be subject to attenuation in the passive case, not in the active one.
This is an interesting point that I have been thinking about a lot lately. I really don't know how much of an effect it has, or could have. Anyone have any expanded knowledge on this subject?
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 26th October 2012, 07:21 PM   #535
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Active vrs passive
he said no difference regarding dynamic/compression....
not that it didnt sound differnt at all
btw, I wouldn't mind making my speakers active, not at all
actually, I would like to
and I would try my best to make them sound the way they do now
but if I continue my ideas about big tweeter horns and compression drivers, they will surely be active, no doubt about it
and in the end the whole speaker will probably be a mixed active/passive hybrid, and with passive tone controls
Old 26th October 2012, 07:52 PM   #536
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by CopperTop
My perception is that passives begin to sound strained at high volume, while the actives just keep on keeping on.
Originally Posted by Pano View Post
How high a volume are we talking about? I can ceratinly understand that in P.A. application - tho Danley's Unity Horns seem to do OK - but in small rooms?
Do you think it's related to the drivers?
Drivers impedance rises when they heat, which changes the frequency response when used with a passive crossover.
High frequency drivers have little voice coil mass, so this effect can happen quite rapidly.
The offset horn used for midrange in Danley's Unity or Synergy horns is an acoustical bandpass, it reduces distortion components whether used active or passive.
Old 26th October 2012, 08:12 PM   #537
On Hiatus
SY's Avatar
Active vrs passive
You're not that far away, come hear it for yourself.
Passive, the stock speakers could go far louder than I could stand with no sign of compression or strain. That was one big reason that they got rave reviews from a notorious rocker who used to write for Stereophile. Active didn't change that, it just made the bass smoother (through crossover and midbass chamber modifications) and more extended.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th October 2012, 08:23 PM   #538
Active vrs passive
yes, its true if you play very loud
but coppertop only mentions better bass
a friend have very old Cervin Wega, and they sound very 'effortless'
but only with good and big power amps
the more the merrier it seems
funny tho, I think someone told me there is no xo on woofer
hard to believe
Old 26th October 2012, 08:45 PM   #539
weltersys's Avatar
hard to believe
A lightweight, low sensitivity small dome tweeter can quickly change in impedance at less than 90 dB at one meter, a level I would not consider particularly "loud".
The change in impedance will change the frequency response when using a passive crossover, low sensitivity tweeters without a resistive pad will sound "more different" at high level than a efficient compression driver with a resistive pad that may be reducing the power by 90%.
I recently used parts from a pair of old Cerwin Vega 3 way cabinets, they had no in line components on the woofer.
There are many passive crossover speakers that use no crossovers on the woofers, if the acoustic rolloff is adequate to start with, no need to add a coil, or a coil and a capacitor.
Old 26th October 2012, 09:39 PM   #540
I grew up in ChiTown ... southsider (around Kelley HS). If I ever make a run for polish sausage and TomTom tamales, maybe we can hook-up :P
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright ©1999-2017 diyAudio
