#481 |
just another
Actually although I've not heard it on vinyl, I suspect the same can be said about Pink Floyd's Animals... maybe it is just a Pink Floyd phenomenon....
Tony. |
#482 | |
And then the difference between 96k and 44.1 or 48k is a fair bit smaller than the difference between 16 and 24bit. With DACs money thrown at it is not necessarily a deciding factor. There used to be a post (now sadly gone) on another site where somebody posted otherwise identical recordings but one file was recorded through a cheap ART, one through a £350 Echo Audio AF12 while the third through a £8000 Apogee Rosetta. While everybody of the dozens of people who tried to identify the three could easily identify the ART as the cheapest/worst the differences between the Echo Audio and the Apogee were way to close to tell. There were very, very subtle differences but slight majority preferred the Echo unit in the end if I remember correctly. Either way not enough to draw any conclusions about quality or accuracy between the two. To my ears the differences between convertors is smaller than those between different amplifiers which leaves speakers/drivers as THE major determinant of sound quality. |
#483 | |
However, getting the most out of a DSP is more than twisting a couple knobs. One can fail to produce satisfactory results with a cheap unit just as well as with the best on Earth if you don't spend some time with it. (thinking that there's more of this going on in this threads' posted opinions than anything else) What I like about the active approach is that you aren't limited in driver selection. Combining drivers, that one wouldn't normally care to make the effort for, can be done with satisfactory results. The guys with cradle to grave control over their components and/or intending to use low order xo's will, most likely, choose passive and have outstanding results. The additional complexity (manufacturer) or expense (avg. diy guy/*manufacturer wanting a simple audio solution) isn't worth it to these folks. Getting the drivers to work together is the important part ... the rest is "cAke DeCoration". Sky's the limit for sure. .. but the users decision to use active/passive when assembling their system shouldn't include the notion of a second mortgage. |
#484 |
192 for digital delay, for time aligning/phase aligning drivers is somewhat necessary. The minimum you can delay by is one sample period and 96 and 48 don't quite give you the precision required.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#485 | |
Really good passive crossovers are very expensive, btw. A DIY class-A discrete crossover wouldn't be so expensive to make, comparatively. |
#486 | |
For example there's a lot (LOT) of things written on the net about the "horrible brick-wall filters", but when correctly realized they can sound allright. And to correctly realize one, it is an expensive affair (lots of precision inductors). The first digital multitracks had non-oversampling DACs coupled to classic brickwall (i.e. 9th order) filters and top mastering engineers of the day compared them favorably to their golden analog multitracks... The key -as always- is on the implementation. Last edited by flavio81; 24th October 2012 at 03:34 PM. |
#487 | |
On the inner grooves there is less linear groove speed available. Thus, the highest frequencies get more difficult to read by a conventional stylus. In consequence, most mastering engineers intentionally reduce the HF energy (i.e. by equalization) at the inner grooves, to prevent this. Thus, limited HF extension available. Or they choose to not do this, and the high frequencies at the inner grooves may be a bit harsh if they're not read with the narrowest elliptical (.2x.7 mil) * Another choice is to significantly reduce the cutting level at the inner grooves. Most of these choices will make the audio on the inner grooves different from the outer grooves, unless the record has been mastered with great care and your cartridge has a narrow-side-radius stylus, and your TT system is perfectly aligned. * Harmonic distortion skyrockets at the inner grooves because of increased groove modulation curvature, which may reduce so much that the stylus does not correctly fit in the groove but ride up and down (pinch effect). This increases distortion. Last edited by flavio81; 24th October 2012 at 03:36 PM. |
#488 |
Why off-topics, why needles and grooves? Because the topic was not well defined.
Let's still start from definitions. 1.) Active: design, build, fine tune the system, enjoy the music. 2.) Passive: Discuss on forums endlessly classifications of systems and of their parts, which one is better and why. Conclusion: I prefer active.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#489 |
Well said Wavebourn. With my properly implemented DEQX, multi-amp system I have finally achieved EXACTLY what I wanted after years of randomly trying off the shelf passively crossed speakers. I am sure there are people out there who accidentally or technically hit on a perfect amp-speaker-room combination. I never did and all I ever wanted to do was listen to recorded music as close as possible to a real live event. I now have that and I have been EXTREMELY fussy in my pursuit
#490 |
| Active or Passive | bjackson | Multi-Way | 30 | 4th April 2005 10:49 PM |
| Passive into active | MethMan | Multi-Way | 8 | 12th January 2005 04:58 PM |
| Active of passive | audiobomber | Multi-Way | 9 | 31st July 2004 02:31 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
