Active vrs passive
Active vrs passive
Old 22nd October 2012, 11:50 PM   #401
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Active vrs passive
Originally Posted by flavio81 View Post
BTW having read about the non-linear effects of some capacitor types in audio, sometimes i wonder if the inductor isn't such an "evil" component.
Like capacitor with air or vacuum dielectric is no more evil than a coil without magnetic core. But if you add a core to the coil it is more evil than dielectric in the capacitor.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 23rd October 2012, 12:13 AM   #402
Wavebourn's Avatar
Active vrs passive
Originally Posted by planet10 View Post
What you describe is a powered speaker. It can be active or passive.
Powered speaker can be passive, if power is used to create constant magnetic field only. But speaker with the amp inside can't be passive. I did not describe powered speaker. I described exactly active speaker.
Old 23rd October 2012, 12:27 AM   #403
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
For the size required they almost have to be cored and it is far from trivial... calculate the value needed for 1st order into 100k impedance.
Go lower impedance and then the value is reduced proportionately. But don't go too low or losses become significant. I've started playing with passive line level LC quite recently and an impedance of 100-200 ohms seems to work. But its very early days yet in winding my own inductors - perhaps longer term stability is going to be an issue. I'm not using air-core as one of my values is 11.4mH
@Wave - what's the SRF of the primary of your 12H trafo? IOW, what's the parasitic shunt capacitance? Also what core material?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 23rd October 2012, 12:35 AM   #404
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Active vrs passive
I know that, but that is the input impedance of my amps. I'm not going to change that.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd October 2012, 12:36 AM   #405
frugal-phile(tm)
planet10's Avatar
Active vrs passive
Yes it can. Lots of cheap storebout monitor speakers that are 1 amp channel built in driving a 2-way with a passive XO.
dave
Old 23rd October 2012, 12:41 AM   #406
Wavebourn's Avatar
Active vrs passive
Then they are active speakers.
Honestly, I don't like this terminology, even if it is domestic. It is confusing, artificial. Call me anti-patriot, but I prefer international terminology accepted by the outside of the forum world.
Old 23rd October 2012, 12:42 AM   #407
abraxalito's Avatar
Looks like you're not really cut out for passive LC then
Old 23rd October 2012, 12:43 AM   #408
MiiB is offline MiiB  Denmark
Dave, you can just add the lower impedance parallel to the input impedance of your power amps.(not change the amp itself)
I have have even built at three-way like this, where I took the signal over a 20 ohm resistor (serial filter) posing as the basedriver in a system with powered woofer.
Old 23rd October 2012, 12:49 AM   #409
Wavebourn's Avatar
Active vrs passive
I don't remember. But core material is fantastic! Huge inductance for such tiny size.
Old 23rd October 2012, 12:50 AM   #410
abraxalito's Avatar
Is it commercially available or a 'special' ?
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
