Active vrs passive - Page 39 - diyAudio
Old 22nd October 2012, 10:52 PM   #381
Pano is offline Pano  United States
Pano's Avatar
Yes Falvio, I agree. For me passive have certain practical advantages. It took me many years and much listening to admit that they can be just as good (sometimes better) than active crossovers. Yes, I was an active crossover snob! After a good 12 step program I am now able to live a passive life. And you know what? I'm happy.
Old 22nd October 2012, 11:02 PM   #382
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by flavio81 View Post
I don't understand your point. The goal here is the accurate reproduction of the original source signal. This shouldn't be about what suits your taste better, but what works better, and why should it work better.
Let's start from the definition. What is passive, what is active. If I use passive LC filters before active power amps for woofers and for subwoofer, is it active, or passive? If I use passive capacitor after active power amp that drives directly midrange array, and tweeter array through the cap, is it passive or active? If digital Audyssey takes care of the rest, is such system active, or passive?
I would understand if the question was, "Should I add crossover inside of my speakers, or should I add as well amps inside of them"?
Because active speaker means a speaker with an amplifier inside. Passive speaker means a speaker without an amplifier inside. Which are better, which are worse? The question is irrelevant. If they were designed by carpenters with their understanding of physics there is a slight chance that they would sound somehow, but in the most cases no matter are they active or passive, they will sound like a furniture.
The Devil is not so terrible as his math model is!
Old 22nd October 2012, 11:04 PM   #383
That is very interesting. I guess you have a remarkable amplifier, and a remarkable crossover as well.
Old 22nd October 2012, 11:07 PM   #384
Wavebourn's Avatar
Also he has very remarkable speakers. People who heard his system said that it fools imagination as if the performers play and sing in the room, in front of them!
Old 22nd October 2012, 11:08 PM   #385
That's a passive line-level crossover. Usually "passive" is shorthand for passive crossovers at the amplifier outputs. Semantics.
Depends if that capacitor is only there as a DC-protection cap or not.
It's a hybrid system.
This is your understanding of the term. I do not agree with your usage of the term.
Old 22nd October 2012, 11:11 PM   #386
Not to steer away the thread, but this is exactly what i got with reasonably priced speakers, by simply adding 2 rear channels and feeding the following to the rear speakers:
Rear Left: (L-R) delayed 5 to 15 mSec
Rear Right: (R-L) delayed 5 to 15 mSec
Tricks invented in the 40s by the Phillips engineers...
Careful adjustment of the rear levels expanded the front soundstage dramatically and indeed projected the musicians to the front in a wide arc, in which you could discern perfectly what was going on. Quite remarkable.
Old 22nd October 2012, 11:14 PM   #387
frugal-phile(tm)
planet10's Avatar
Dave, pick any two woofer and sqwawker (or a sqwawker and a tweeter) and they will be more mismatched than the most dissimilar amplifiers!!
In your dreams maybe.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd October 2012, 11:15 PM   #388
Wavebourn's Avatar
At least my term has some useful meaning.
Also, here is the proof: the majority agrees with me! http://lmgtfy.com/?q=active+speaker
Old 22nd October 2012, 11:18 PM   #389
dave
Right, so two different-frequency-range drivers (i.e. midrange and woofer) will have a more closely matched transfer function than two amplifiers?
Can't believe that.
Old 22nd October 2012, 11:18 PM   #390
frugal-phile(tm)
planet10's Avatar
L
This has been argued ad nauseum.
What you describe is a powered speaker. It can be active or passive.
For me an active system is one where each driver has their own amplifier, XO (if any) in front of the amplifiers.
Passive takes the amplifier output and divides it, then sends to the speaker.
It doesn't matter where the amps are, but where the XO is.
dave
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright 1999-2017 diyAudio
