Active vrs passive
Active vrs passive
Old 21st October 2012, 12:06 AM   #271
Barleywater is offline Barleywater  United States
Creating a driver situation that gives a flat frequency response and a linear phase response (be it horizontal or tilted) is not the penalty, it is the prize.
Andrew
Old 21st October 2012, 12:15 AM   #272
On Hiatus
SY's Avatar
Active vrs passive
Originally Posted by James Lehman View Post
CAD modeled freq response tells you nothing of the control the amp has to start and stop the cone motion.
Actually, that's exactly what it tells you- the amp can be modeled as a source impedance and variations in it examined (as Pano just showed dramatically). When you compare CAD versus measurement in the bass with real speakers and real amps, it's stunningly accurate.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st October 2012, 01:14 AM   #273
Pano is offline Pano  United States
Pano's Avatar
Active vrs passive
It does tell you a lot, as SY has mentioned. It's not perfect, but pretty good.
Below is the simulated step response of the same box and driver with the same series R 0R, 0.2R and 2R. You can see that there is about 1dB more overshoot with the 2 Ohm source impedance.
I can do some actual measurements if you like, or you can do them yourself.
No argument that lower output impedance can sound different than high, but it's nice to know why.
Take the Speaker Voltage Test!
Old 21st October 2012, 05:19 AM   #274
demeterart is offline demeterart  Greece
demeterart's Avatar
hello Wavebourn
it is quite clear that you have no idea what my point was. if you care please read it again otherwise forget about it.
Old 21st October 2012, 05:39 AM   #275
James Lehman is offline James Lehman  United States
James Lehman's Avatar
Active vrs passive
There are things you can do with active crossovers and multiple amps that you simply cannot do with a single amp and a passive multi-way crossover.
You have total buffering and isolation between the stages.
There is no getting around that.
If there was a total and finite winning argument for single power amp and passive crossover then active multi-amp would not be used in professional audio applications.
It is.
Regularly.
James.
Old 21st October 2012, 06:06 AM   #276
Arty is offline Arty
i can't say i did many designs with passive or active.
but there are things that come into my mind.
the series resistance of passive components is kindof the first one, allready pointed out by some.
surely inductors used in a crossover could in theory couple signals between eatch other, something no one would like. clipping of the amplifier driving the woofer will not affect the tweeter. But allso has to mention a system should never be clipping. so thisone is pointless.
CEMF is more intresting, specialy with high sensitivity drivers. here an active design does indeed have its advantage. Component value matching. hard to find trimmable capacitors that can be utilised in a passive crossover, but not hard at all for an active one.
costs are mentioned with active filters as more poweramps are needed. well.. if one takes a look at crossover part prices, it is likely that DIY poweramps may be a lot cheaper.
designing both of them is hard. But active is more felxible from a point of view.
You can't just change an inductor as easyli as get a trimm cap / resistor.
delay alligmenting speakers with passive crossover is managable, but with active allpass filter its just so mutch less of a problem.
from diy point of view the "findling" part is mutch less of a hard task with active filters.
there has gotta be verry good points besides passive filters, but i can't realy think of any.
Old 21st October 2012, 06:30 AM   #277
Active vrs passive
Yep. I have designed and built my share of passive crossovers. I get them. I like them for what they do.
But, I really would like to hear how they are better than active with multiple amps.
I know they work.... but make a case for how they are better.
Old 21st October 2012, 06:51 AM   #278
MiiB is offline MiiB  Denmark
There are things you can do with passives you simply can't do with active
Old 21st October 2012, 07:40 AM   #279
Remlab is offline Remlab  United States
Michael
You guys make some of the most beautiful looking speakers in the world. Stunning. O.K., way off topic question; What are the distortion figures like on your single ended planar magnetic tweeter? If you don't mind me asking..Or is it a true ribbon?(The apparent traces may have thrown me off)
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 21st October 2012, 07:42 AM   #280
StigErik is offline StigErik  Norway
StigErik's Avatar
Some examples please.....?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
