Active vrs passive
Active vrs passive
Old 20th October 2012, 05:36 AM   #231
James Lehman is offline James Lehman  United States
James Lehman's Avatar
Active vrs passive
a well designed multi-way passive crossover speaker is much closer to a nominal impedance than a single woofer.
Old 20th October 2012, 05:42 AM   #232
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Active vrs passive
Really?
So, if SY in order to align SPLs increases inpedance on lows by adding transformer the speaker is no more "well designed", despite it sounds better?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 20th October 2012, 05:44 AM   #233
Active vrs passive
Nope.
Well designed means that there was a good match between the elements to begin with!
Old 20th October 2012, 05:46 AM   #234
Wavebourn's Avatar
Active vrs passive
Nope.
I see. Sound quality does not matter anymore. Means are real targets now.
Old 20th October 2012, 05:52 AM   #235
Active vrs passive
With as many choices as there are out there for all kinds of drivers why would anyone (who knows what they are doing) choose a woofer with a higher SPL than the mids or tweets for a multi-way passive crossover system and then try to fix that problem with a transformer?
So now you have the DC resistance of both the secondary coil of the transformer and at least one coil in the passive crossover in series with the woofer.
That's very counter productive.
James.
Old 20th October 2012, 05:57 AM   #236
Wavebourn's Avatar
Active vrs passive
Do you reproduce DC? I don't. I assume SY does not. So what is that DC resistance about?
Old 20th October 2012, 07:28 AM   #237
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
With active an crossover, you can also easily use speakers of different impedances
You don't have to have drivers with the same impedance in a passive speaker. IE- 4 ohm woofer, 8 ohm mid, and 6 ohm tweeter is perfectly doable.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 20th October 2012, 08:26 AM   #238
demeterart is offline demeterart  Greece
demeterart's Avatar
agreed, provided there is no need to match source/load as in tubes that use transformers and rely on impedance reflection to transfer max. power, although the significance would not be tat important given the outrageous speaker behaviour - impedanc wise.
Old 20th October 2012, 09:41 AM   #239
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Active vrs passive
Later,
Wolf
its not about drivers having different impedances
like you say, no problem at all
its the varying impedance of each driver
that is real big problem, and plays a major role with passive crossovers
active is not troubled with this
Old 20th October 2012, 09:48 AM   #240
On Hiatus
SY's Avatar
Active vrs passive
That's only a problem if you want to use textbook formulas and topologies, rather than modern CAD methods and a bit of creativity about compensation.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
