Active vrs passive
Active vrs passive
Old 19th October 2012, 09:18 PM   #221
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
The phase margin at gain=1 @MHz ?
Old 19th October 2012, 10:42 PM   #222
Remlab is offline Remlab  United States
Originally Posted by SY View Post
OK, so one more try- how do we deal passively with a woofer to match its spl with a less sensitive mid and tweeter without affecting the efficiency of the alignment? Clearly, a series resistance won't fulfil the challenge.
Glue dumbbells to the woofer cone?
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 19th October 2012, 10:58 PM   #223
On Hiatus
SY's Avatar
Active vrs passive
Originally Posted by James Lehman View Post
Using a transformer is a bad idea. If the woofer, mid and tweet all are the same nominal impedance to start with then that will get all screwed up with a transformer on the woofer. The only way to compensate for that is to give the low end current another path around the woofer. Bad idea! There goes your SPL!
The whole POINT was to answer your question about altering the SPL of the woofer relative to the rest of the speaker. That's what it's SUPPOSED to do. The transformer does so without any change in efficiency or the alignment. Yes, it changes the impedance- so what? Let's say you have an 8 ohm nominal woofer that needs a 6dB reduction in sensitivity. Its impedance will vary from (say) 6 ohm below resonance to maybe 30 ohms at resonance to 10 ohms above resonance; these are not atypical numbers. 2:1 stepdown means 4:1 impedance transformation, so the speaker impedance ends up varying from 1.5 ohm below resonance to roughly 8 ohms at resonance to 2.5 ohms above resonance. A decent SS amp will have zero problem with that- its source impedance is low, well under 0.1 ohm. So.. the passive solution works. It's not convenient- a big bass transformer is heavy and bulky, and biamping will be cheaper- but it's absolutely doable if you want a passive solution.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th October 2012, 11:34 PM   #224
Jonathan Bright is offline Jonathan Bright  Australia
I understand that many years ago B&W used a transformer to lower the sensitivity of the 10" bass unit in their 3 way DM6 (also known as "The Pregnant Penguin". If you ever see a photo of a gloss white version you'll see why.). The cross over was published somewhere here a year or two ago.
Edit; and just for completeness the thread is; DM6 Recap. Post #1 24 June 2011.
Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 20th October 2012, 12:29 AM   #225
Why would Linkwitz say this as a simple "Case closed" statement if it wasn't true? He is an an authority on active vs passive if there ever was one. Yet he claims that the reason is quite simple..
"Crossovers may be implemented either as passive RLC networks, as active filters with operational amplifier circuits or with DSP engines and software. The only excuse for passive crossovers is their low cost. Their behavior changes with the signal level dependent dynamics of the drivers. They block the power amplifier from taking maximum control over the voice coil motion. They are a waste of time, if accuracy of reproduction is the goal."
Old 20th October 2012, 01:13 AM   #226
gedlee is offline gedlee  United States
gedlee's Avatar
Linkwitz is hardly an irrefutable source on the subject. "A little biased, me thinks"
Earl Geddes Gedlee Website
Old 20th October 2012, 01:29 AM   #227
Hardly an irrefutable source? He knows at least as much about crossovers as you do about HOMs. Maybe even more..(Trying to be funny. Kind of.)
Old 20th October 2012, 01:54 AM   #228
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Active vrs passive
I don't care.
I have "passive" capacitors in series with tweeters, LC filters for woofers and for subwoofer, but before corresponding power amps. Digital Audyssey does for me the rest.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 20th October 2012, 03:50 AM   #229
Brett is offline Brett
Brett's Avatar
Originally Posted by Pano View Post
Neither do I, but that's not what I was getting at.
Well, what were you getting at?
Old 20th October 2012, 04:16 AM   #230
Wavebourn's Avatar
Active vrs passive
Oh. That's nice. Screw up the impedance of the whole system.
Are you serious?
Active vrs passiveHide this!Advertise here!
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Passive into active MethMan Multi-Way 8 12th January 2005 04:58 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
