SAND LINER - DIY
SAND LINER - DIY
Old 14th October 2012, 03:36 PM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
yes adequate airing time is required or you run the risk of loosening the glue holding the cone to the surround!
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 16th October 2012, 10:31 AM   #12
ODougbo is offline ODougbo  United States
Default Keep on Trucking
Awkward...did you take pics
I let the solvent base glue dry 12 hours per coat, outside, in the wind/sun.
About 4 hours for the clear poly; It seems fine, don't smell any glue, etc.
Applying oak veneer (cheap stuff-ebay) so thin can't sand it. Just just using yellow glue, weights, razor knife to apply it.
Old 16th October 2012, 12:53 PM   #13
sippy is offline sippy  United Kingdom
Looking good there Odougbo. I'm having a right job deciding how to finish my EmKens.
Old 21st October 2012, 12:31 PM   #14
Should have these done soon.
Made new sub-bases for crossovers - looks like I'll need new stands.
Old 22nd October 2012, 09:55 AM   #15
Default Its Official - no difference Plywood and MDF
Well none that I could tell anyway. The darker wood boxes are MDF, the Oak boxes are plywood, both have "sand walls" everything else is the same.
I've been building these out of parts that were stored in boxes, so they all have been low cost projects. I'd buy some new woofers if I could find better one(s).
I'm sure they are out there, I just know where to start (these have really cool bass). [Peerless woofers shown]
The Vifa tweeters are pretty nice, probably the best of the tweeters in the $30 range.
Old 22nd October 2012, 10:15 AM   #16
Frankie Carbone is offline Frankie Carbone  United States
Just curious. Has anyone ever tried this with #12 lead shot? It is lead ball for shotshells and you can buy it here.
BPI Lead Shot #12 10 lb Bag
1.25 mm diameter (0,05 inch) but quite pricey for a 10 lb (4.54 kg) bag at US $44.
What do you all think? If one were willing to spend the money do you think it would make a difference?
Old 22nd October 2012, 10:49 AM   #17
you know..I tried lead in similar boxes - 1" mdf with sheet lead. The sand works a whole lot better.
Old 15th December 2012, 11:29 AM   #18
Default Sand Walls DIY
Here we go again.
I'm really enjoying the 1st pair (which are finished).
Old 15th December 2012, 05:51 PM   #19
tvrgeek is offline tvrgeek  United States
I thought lead shot was banned. Most shot is steel.
Anyway, I think this is expending great efforts on things that are not the biggest problem. Just my experience, but I never found that dime under the streetlight just because the light was better.
Old 16th December 2012, 09:16 AM   #20
awkwardbydesign is offline awkwardbydesign  England
The solvent glue fumed for weeks! My current build uses 4 layers of stone chipped roofing felt, held on with LOTS of bitumen emulsion and nails or screws, depending on hammer access. Allowed to dry for a few hours, they can be brought indoors to be worked on. Much of the work has to be done in my living room; and yes, I AM married.
These are isobarics, crossing over (actively) at 134Hz/24dB octave,.
Click the image to open in full size.Click the image to open in full size.
Supervisor.[IMG]Click the image to open in full size.[/IMG]
SAND LINER - DIYHide this!Advertise here!
phase liner amp space2000 Solid State 17 14th May 2008 04:41 PM
Truck Bed Liner (UK) richie00boy Multi-Way 6 2nd November 2005 11:13 PM
Ute bed liner in Australia Jye Multi-Way 8 6th May 2004 02:07 AM
Truck bed liner tips moving_electron Multi-Way 12 23rd April 2004 12:15 AM
