Old 6th January 2013, 05:46 PM   #291
jmbee is offline jmbee  France
HI Rvrazvan, i made a short description of my simple way to use RePhase as phi équalizer in Foobar (with foo-convolve.)
in French, but may help i hope.
crd
Egalisation fir avec RePhase - Le blog de jimbee
Old 6th January 2013, 05:54 PM   #292
pos is offline pos  Europe
pos's Avatar
Hi jmbee
Yes, your tutorial is more in line with what Rvrazvan seems to be looking for!
Especially the second part, "Test avec filtre iir standard L-R. trois voies", as the first part is dealing with a system that is already quite linear in phase (using a modified DCX2496 for substractive filtering)
By the way, when using the foobar convolver plugin, it is best to uncheck the "Auto level adjust" checkbox.
Old 6th January 2013, 10:14 PM   #293
ra7 is offline ra7  United States
has some one figured out a proper ABX procedure for testing this? I'm afraid I may be halucinating with all the positive changes I'm hearing
Old 6th January 2013, 10:38 PM   #294
Can you switch the plugin during listening ?
A specific attention is needed to exactly match the level with or without convolution .
0.5 dB less or more and test is not decisive .
(play a sine at 1 KHz and bypass convolver to adjust level.)
Old 7th January 2013, 12:35 AM   #295
I don't think bypassing the convolver is a good idea. I generated an impulse that makes no correction and use it as the alternate to the 'fixed' impulse. So, the convolver runs for both the cases.
The big thing is not knowing what is being played when you do the listening.
How about this:
1. Play a song in Foobar with the corrected impulse and record the output of the soundcard.
2. Play the same song with uncorrected impulse with convolver running perfect impulse and record output of soundcard.
3. Play both recorded files through speakers using the ABX plugin in Foobar.
Will this capture the change correctly?
Old 7th January 2013, 01:30 AM   #296
this is the simplest way to adjust level.
time to switch "flat impulse" to "corrected impulse" do not allow an accurate setting.
auditive memory is not required,when bypassing on the fly.
How about this:
yes,you can convolve "offline" and record.
why don't use multiple instance of foobar instead ? play/pause for each instance.
Old 7th January 2013, 09:11 AM   #297
pos's Avatar
Offline convolution looks like a good solution indeed.
SoX should be able to do that using the txt impulse format (never tried though).
What are you loudspeakers and correction settings?
What improvements are you hearing (halucinating? ) ?
Old 7th January 2013, 02:20 PM   #298
Originally Posted by pos View Post
Hi jmbee
Hi Pos,
Thank you for the advice, i have corrected.
Even with the DCX in subtractive-delay, Rephase alows to improve low frequency response, less boominess, more focused.
crd
Old 7th January 2013, 08:28 PM   #299
It's a simple two-way with vented Deltalite2515 and SEOS12. I have large tractrix horns, but they are down for repair at the moment.
I corrected the vented response and the 6th order crossover at about 1200 Hz.
On one particular song, there is percussion with flute. With corrected phase, I seem to latch on to the flute, and everything makes sense. Without corrected phase, I latch on to the bass and the music doesn't make as much sense.
Instruments have more power in space, i.e., better defined, easily localized and I can follow them more easily. In general, it feels more relaxed as I can follow things more easily.
Old 7th January 2013, 08:53 PM   #300
pos's Avatar
Have you tired correcting only the bassreflex, and only the 1200Hz cross, to see where the differences come from?
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Flat EQ Flattens Phase Response weltersys Multi-Way 4 5th January 2012 10:42 PM
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 10 24th May 2011 12:38 PM
Phase/Polarity/Comb Filtering PT1&2 kyrie48 Multi-Way 0 6th January 2009 08:28 PM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
