rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 4th May 2018, 11:25 AM   #2481
arcgotic is offline arcgotic  Romania
In Rephase, there is a Range tab. Click there and set the dB upper and lower points and the dB blue line will be visible (now you don't see it but it is there, filtered by the range default values)
Old 4th May 2018, 11:35 AM   #2482
pos is offline pos  Europe
pos's Avatar
Another solution is to use the "gain offset" setting to bring the passband of the measurement closer to the classic 0dB line.
Old 19th June 2018, 05:48 AM   #2483
architect is offline architect  Netherlands
Originally Posted by RAzZin View Post
Hello everyone,
I can't understand how to make rePhase understand REW measurement files. Attached are the screenshots from REW measurement, I export it as txt, then open in rePhase and what I get is on the 2nd screenshot. What is wrong? I'm using UMIK microphone, Windows 10... Could someone please help me?
i think your measurement is out of range; just adjust it
your phase view can also be adjust; for example from -7200 till 7200 degrees
Old 6th August 2018, 12:50 PM   #2484
BeatnikV is offline BeatnikV
I'm wanting to try this program and I have a question for the Linux users. I am using Ubuntu 16.04 and cannot get rePhase to open in Wine. I've read some are doing this, can someone give suggestions ?
Old Yesterday, 05:09 PM   #2485
esl 63 is offline esl 63
Any updates of rephase?
Old Today, 07:17 AM   #2486
pos's Avatar
Hello
Most recent released version is 1.3.0 from last February.
The only difference in the current development version is the ability to generate frequency responses instead of impulses. I wanted to tweak it a bit and add other things before releasing it, but I have not had much time to work on it lately...
What new features or modifications would you like to see appear?
Old Today, 08:23 AM   #2487
Rajapruk is offline Rajapruk  Sweden
I would like to:
- be able to save all filter settings made as human readable .txt file. Just a list, with newline as separator. This to be able to communicate a set of filters to non-rephase users easier.
- have this list mentioned above automativally inserted into the Notes-input in some way, so that every small EQ etc can have a dedicated note/explanation. For example if there are a mix of speaker and room correction in the same settings-file, then it would be nice to be able to document what is what easily.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
