rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 1st January 2013, 11:58 PM   #181
kgrlee is offline kgrlee
Originally Posted by Pano View Post
OK, but if it's a "perfect impulse" (1 sample on, all others off) it should do nothing, right?
Don't forget to make sure the amplitude response over 20 - 20k Hz is matched to better than 0.1dB for the two impulse responses.
Old 2nd January 2013, 12:27 AM   #182
thierry38 is offline thierry38  France
Originally Posted by john k... View Post
Why? Because you don't know what the effect of the convolution engine is. Yes a perfect impulse should do nothing but which is why it's a good check on whether the convolution engine introduces any artifacts of its own.
you're right,i've been traped several times.
that may leads to wrong conclusion.
with jriver,send a sine at 1 or 2 kHz,check the level and adjust with/without convolution.(with yours ears)
once adjusted,try with musical file.
vsthost allows more flexible adjustemnt in this way but level must be matched perfectly.
Old 2nd January 2013, 01:43 AM   #183
Pano is offline Pano  United States
Pano's Avatar
I tried it with a perfect impulse and no impulse. Same to my ears. I'd have to measure or use the diffmaker software to tell if there is a difference. I'll try that.
Old 2nd January 2013, 05:43 AM   #184
Barleywater is offline Barleywater  United States
Originally Posted by kgrlee View Post
The off axis vertical impulses show loadsa pre-impulse as expected and discussed by Greenfield.
You'll excuse me my old fashioned prejudice as a commercial speaker designer for more than half my life, that finds pre-impulse evil except for certain anti-aliasing filters.
An impulse response is complete characterization of system, the IR doesn’t have a pre-impulse; this is confusing a causal source of information with the transmission of information. IR of transmission system describes what will happen to information that is being transmitted through the system via convolution.
As old fashioned speaker designer, self interested prejudice against tools that flatten the playing field is understandable, but is not an excuse for calling time domain behavior of linear phase filters with frequency dependent amplitude evil.
You see the sense with anti-aliasing filters. See the rest of it.
Old 2nd January 2013, 05:50 AM   #185
bohdan1232000 is offline bohdan1232000  Australia
What will that sound like? Will I even hear it? Time will tell.
Hi Pano,
This may be helpful to you.
http://www.bodziosoftware.com.au/Att...udspeakers.pdf
Best Regards,
Bohdan
Old 2nd January 2013, 09:04 AM   #186
example of 3 impulses responses
a acausal one,centered at t=0,and two causal shift in time.
phase resulting,note the linear X axe.
Old 2nd January 2013, 11:11 AM   #187
john k... is offline john k...  United States
john k...'s Avatar
I think what is being referred to is the effect of summing of axis. At linear phase filter has pre-ringing. But the sum of a HP and LP, at the design point, sums to a perfect impulse. As you move off axis the times of flight for the woofer and tweeter become different and the sum is not longer a perfect impulse. This reveals the pre-ringing, typically in the tweeter's impulse.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 2nd January 2013, 11:22 AM   #188
john k...'s Avatar
Here is an example of the effect of moving off axis for a linear phase LR4 type crossover and a normal. causal LR4 crossover. I've posted this figure many time in the past.
The upper trace in each plot if the input or reference impulse. The lower trace is the measured impulse at the positions indicated. The upper set of plots is for the linear phase system, the lower set for the normal LR4. What you see, particularly in the 15 degree vertical plot, is the development of the pre-response of the linear phase crossover. Of course, it can be argued that with a normal crossover the tweeter response always leads the woofer.
Old 2nd January 2013, 01:34 PM   #189
Hi John,
In above, what is spectrum of reference? And what are driver diameters, what is vertical spacing of acoustic centers, and what is crossover frequency?
Edit:
Sorry, see fine print: 2kHz, but spacing?
And, on axis response should return reference for linear phase conditions, but doesn't, indicating error in level matching. Almost looks like polarity reversal.
Old 2nd January 2013, 02:11 PM   #190
Just add coffee. Top plots.....
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 02:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 09:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 04:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 08:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 11:37 PM
