Old 1st January 2013, 08:04 PM   #171
Pano is offline Pano  United States
Pano's Avatar
I don't have REW. What can I show you in HOLM or rePhase?
Old 1st January 2013, 08:10 PM   #172
impulse of correction in HOLM
it's must start slowly and finish at a maximum at t=0.
can you show the magnified impulse ?
resulting impulse is a symetrical one when you convolve by hand (C=AxB)
Old 1st January 2013, 08:20 PM   #173
Pano's Avatar
I spoke too soon. I do have REW, but can't find the GD display. I'll show you the rePhase impulse in HOLM.
Old 1st January 2013, 08:27 PM   #174
it's seems to be Ok.
check for last version of REW.(5.01)
Old 1st January 2013, 08:31 PM   #175
Pano's Avatar
Will do, thanks.
So you do think this impulse when convolved will correct phase only of my woofer response?
That seems to be what I'm seeing, but could be wrong.
Old 1st January 2013, 08:41 PM   #176
you're right,only in the lows and for the bass reflex delay.(picture below )
a simple way is to do a 4 feets mic measurement of loudspeaker,extract excess delay,and applied theoritical phase linearizationn for full range.
here's your correction (bass reflex 37 Hz)
Old 1st January 2013, 10:22 PM   #177
john k...'s Avatar
Originally Posted by Pano View Post
I don't know John. I just exported the impulse wave from rePhase and plugged it into my player software - JRiver Media Center. I could be that it's upside down, I don't know. Will try to figure it out. I either have convolution turned on or turned off, if that's what you mean.
If you turn the convolution turned on and off I don't think it's a valid comparison. What you need to do is keep the convolution on all the time and change the impluse being processed.
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 1st January 2013, 10:36 PM   #178
Originally Posted by john k... View Post
If you turn the convolution turned on and off I don't think it's a valid comparison. What you need to do is keep the convolution on all the time and change the impulse being processed.
Why is that John?
Old 1st January 2013, 10:36 PM   #179
Pano's Avatar
OK, but if it's a "perfect impulse" (1 sample on, all others off) it should do nothing, right?
I'll try it.
Old 1st January 2013, 10:51 PM   #180
john k...'s Avatar
I'll try it.
Why? Because you don't know what the effect of the convolution engine is. Yes a perfect impulse should do nothing but which is why it's a good check on whether the convolution engine introduces any artifacts of its own.
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Flat EQ Flattens Phase Response weltersys Multi-Way 4 5th January 2012 10:42 PM
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 10 24th May 2011 12:38 PM
Phase/Polarity/Comb Filtering PT1&2 kyrie48 Multi-Way 0 6th January 2009 08:28 PM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Copyright ©1999-2013 diyAudio
