#151 | |
Crossing over between two drivers with large differences in directivity at chosen crossover point is perfect example of poor design choice, if off axis performance is priority (a great one IMO with omni and dipole speakers). Use of steep crossover results in abruptness, but shallow slope seeking concept of smooth blend results instead in increasing ripple off axis in overlap region due to differing change. I've posted two-way fully active DSP PC based design utilizing direct inversion of driver IR for linearization; DSP Pluto Clone. I've applied crossovers as IIR filters from 24dB/octave to 192dB/octave both as minimum phase filters and as linear phase filters and also FIR filters of various tap counts to create range of crossover slopes. Going from 24dB/octave to 48db/octave nets some measurable and audible improvements in distortion performance, and further improvement to 96dB/octave with IIR based filters. Minimum phase crossover at 96dB/octave didn't sound as good to me as linear phase version and the linear phase version didn't perform as well as FIR with same number of effective taps, i.e. filters truncated to length where sample values are 100dB below peak value. Speaker with full linearization passes arbitrary waveform within bandwidth, and music playback, in particular acoustic music and voice, is most natural sounding that I've heard from any loudspeaker. Closest comparison is electrostatic headphones. Regarding latency: My understanding is JRiver Media Player has controls for video delay, and certainly an integrated video/audio DSP approach is possible. |
#152 | |
If I may ask a few naive questions ..
Got any off axis measurements of the same system including impulse responses ? Also at slightly different height? Bit suspicious of your "speaker response looks when one of the drivers has leads reversed". All the fuzz has gone. Last edited by kgrlee; 31st December 2012 at 03:44 AM. |
#153 | |
be careful with REW export,IR is not time windowed. with REW,you need to add delay and cut the lenght of IR.(if you take a look at IR,it's start at t=0) i've used to. open audacity,add a silent...etc the better and simple way is to use HOLM.you can limit negative and positive number of sample when you are exporting a IR. just a advice to avoid issues.
#154 | |
Impulse response & response eg 100mm above & 100mm below your 'design' height for your version please? [edit] Make that +15, +30 & -20 degrees to compare with his. [/edit] Linkwitz uses a 1kHz xover which I see you've followed. That should certainly alleviate certain evils in high slope xovers but I'd be interested to see your impulse responses at different heights and also the frequency responses to compare with his. Gotta admit I'm impressed by Pluto. It is the most innovative of Linkwitz's designs and I nearly forgive him for appropriating a xover configuration that speaker designers have known about for years before he turned up and put his evil name to LR. ![]() Would still like to know the answers to ..
#155 | |
I have been reading posts for a short while only. I am glad to see such interest in linear-phase technology. Coupled with HBT equalization, it's the most powerful processing there is for loudspeakers. Yes, the latency figures I quoted are for linear-phase only. Minimum-phase latency is around 65ms for 8192 and 130ms for 16384bins. FFT length is controlled by the UE buffer size automatically. Best Regards, Bohdan |
#157 | |
I would be very happy to use rePhase-generated filters if I actually knew how to use the tool... It's not obvious to me how I load a raw impulse response and view the phase/amplitude result of it convolved with the filter. Currently it seems like a tool that can generate a filter if I study a graph of phase/amplitude of my driver in another tool and type the values into rePhase. Have I got this wrong? (version 0.9.2) |
#158 | |
Design point is 9" from tweeter face. Tweeter axis is angled about 5 degrees up from horizontal, and microphone is placed slightly below tweeter axis. Measurements are in living room. Main software is Cool Edit Pro 2.1. Familiar with Praxis, Holm, ARTA, REW, and Audacity. Inverse transfer functions are created with Kirkeby transform. Off axis responses and phase are posted here and here. From perspective that speaker response is flat to fractions of a degree at design point, with driver linearization prior to crossover filtering, the reverse null is fuzz free too, along with image coherence through crossover region. |
#159 | |
Aha! So you might know something about the so-called Stochastic Interleave alignment described here: http://www.essex.ac.uk/csee/research...ssing%20LS.pdf ...which does seem relevant to what you say above. The aim seems to be to mix up the comb filtering between drivers through the crossover region, allowing you to have shallower crossover slopes without obvious audible artefacts. I've coded it into my crossover system, but haven't been able to try it for geographical reasons (it's Christmas and I'm staying elsewhere from where my system is :-( ). Does it work?! |
#160 | |
export IR as .txt file from rephase. import the IR.txt from HOLM you can do math.AxB or A/B...you need the files with the same extension. (2 .txt file or two measuremnt). |
| AVX based FIR VST, crossover / EQ / DRC and delay | KOON3876 | PC Based | 97 | 26th November 2012 07:18 AM |
| Flat EQ Flattens Phase Response | weltersys | Multi-Way | 4 | 5th January 2012 10:42 PM |
| FIR linear phase plugin for MiniDSP? | diyjb01 | miniDSP | 10 | 24th May 2011 12:38 PM |
| Phase/Polarity/Comb Filtering PT1&2 | kyrie48 | Multi-Way | 0 | 6th January 2009 08:28 PM |
| Phase EQ using FIR filters | Grasso | Multi-Way | 2 | 2nd July 2003 10:37 PM |
