I am planning to use magnets to hold the speaker grilles in place. Could someone upload some pics or a scanned sketch illustrating how it is recommended to fit the magnets? I was thinking of fitting a metallic (magnetic) cubic insert into the front baffle from the back, and then fitting small magnets close to the corners of the grilles. Doubts: will the magnet affect the loudspeaker performance? What magnet type is recommended to use for this? Thanks to everybody, B
#2 |
Here is a solution I have used. Follow the link for product and diagram:
http://www.partsexpress.com/pe/pshow...number=329-045 |
#3 |
A lot of our products use magnets from a factory in China and I have to say that rare-earth magnets are just great for holding things together. Note: Rare-earth = neodymium = NdFeBr composition.
Use magnets in the the grill and steel screws in your enclosure. With neodymium magnets, the holding force will be strong enough and yet not so strong that it is difficult to remove. Two magnets in a bond are extremely difficult to pull apart and may cause enough stress to mess up your grilles. Estimate that a neodymium button magnet sized at 3/8"dia x .125" thick (10mm x 3mm) will easily pick up a pound (1/2 kg) of weight. :)ensen.
Those who claim to be making history are often the same ones repeating it. |
#4 |
Hi since your in the UK Maplin sell neodymium magnets some with holes others you recess in to the baffle.
Peter |
#5 |
I'm using Velcro to hold my grills. I usually don't use grills at all, but found out that a simple solution to grills is a window based airconditioner filter, which attaches to the speakers with Velcro. Basically, the same idea that Wilson incorporates in their speakers. The filter material is also pretty transparent and only some of the highest frequencies are "filtered"
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#6 |
...which to my ears usually isn't a bad thing.
I also use a similar material in my car to completely cover the fiberglass pods I made to hold my Seas coaxes. It's a marine carpet that is fairly transparent when you hold it up to the light, which translates into almost completely transparent to sound, and in my opinion, it tends to be not-so-transparent in some places that seem to be almost an improvement. |
#7 |
Just an idle [and perhaps silly] question; why don't you use proper grille clips? its not too difficult to do
tomcat:
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#8 |
I'm thinking of doing this too. I saw that Creative Sound offers this kit: http://www.creativesound.ca/details.php?model=GRILLMAG
#9 |
Search ebay for neodymium, you'll find lots of innexpendive stuff.
#10 |
I searched and got 5 returns all the same identical pairs of headphones.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
| waveguides and grilles | tom31415926 | Multi-Way | 4 | 17th November 2007 08:58 AM |
| Cheap speaker grilles - computer fan covers? | Spasticteapot | Multi-Way | 12 | 1st December 2006 11:35 PM |
| Dayton Finished Cabinets - Grilles | zenon | Multi-Way | 7 | 10th January 2006 09:42 PM |
| How to remove glue from metal speaker grilles??? | Bull | Multi-Way | 9 | 11th May 2005 03:47 PM |
| How to make speaker grilles: | GrahamnDodder | Multi-Way | 0 | 18th October 2003 06:52 PM |
| Page generated in 0.09847 seconds (77.52% PHP - 22.48% MySQL) with 11 queries |
