Old 19th October 2012, 05:40 PM   #21
frugal-phile(tm)
planet10's Avatar
Originally Posted by Bare View Post
Why? with a 'decent' quality 12" woofer would you even want, let alone Need a Sub?
Because, in most rooms, it takes multiple (sub)woofers located in much different places than where the mains are optimally placed to get smooth, well distributed bass.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th October 2012, 08:35 PM   #22
Dilletante, tinkerer and beggathoner supreme
Moondog55's Avatar
Assuming a box width of 450mm to suit the 10 inch woofer i would suggest a simple 2.5Way speaker.
This is a first project and needs to be kept reasonably simple and as cheap as possible. having said that the Marshal Leach XO is as good a starting place as any.
Putting in a .5 woofer at the F3 or F6 point for baffle step losses and using the small Vifa mid in a sealed box would be my starting point.
F3 point is 255Hz in a 450mm box
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 19th October 2012, 11:06 PM   #23
system7 is offline system7  United Kingdom
system7's Avatar
The Marshall Leach twoway design is what you'd call a genuine bookshelf speaker. The smallish simple (0.42mH) inductance on the bass coil means it needs to be positioned close to a wall for good bass performance. The plus is that you gain efficiency by doing this, because you have less midrange rolloff on the 6.5" (0.6mH) bass cone. The downside is you let through a lot of bass cone breakup which sounds harsh to the trained ear.
The circuit below will get rid of a lot of that cone breakup noise and have more bafflestep, so might sound best on a stand. The Tweeter Zobel will work with most 0.05mH tweeters. The 4.7 ohm "select on test" tweeter attenuator will match levels well enough on a crossover around 3.5kHz. Perhaps 3.3 ohms will be optimal, but see how it goes. Bright treble is quite annoying.
If you want a three-way design, I'd really not want to be involved. Way too complex.
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK.
Old 20th October 2012, 12:00 AM   #24
Bare is offline Bare  Canada
dave
OK.. Just like in a Cineplex??
In truth though I've Never Ever actually experienced that particular problem. And here I thought Subs were a sop to a poor setup. Silly Me.
Old 20th October 2012, 12:52 AM   #25
frugal-phile(tm)
planet10's Avatar
Bad example.
dave
Old 20th October 2012, 01:23 AM   #26
Moondog55's Avatar
I tend to agree with this for beginners, however using point 5 woofers is technically easy
Old 20th October 2012, 02:01 AM   #27
Keswick is offline Keswick  Australia
Thanks for all your input guys, I am reading all this. Adrian.
Old 20th October 2012, 03:11 PM   #28
Originally Posted by wintermute View Post
Hi Sreten, I'm curious because I see you post about no BSC designs
often, but I want to know exactly what you mean by it.
1. there is no obvious BSC compensation circuitry in the crossover
or
2. you can tell by looking at the crossover that does not have
any compensation at all and the speaker will have thin bass.
Tony.
I can't see the difference. Basically any design with the tweeter
level set to the bass/mids sensitivity has no BSC, may be on
purpose (not good as at least some is needed), or ignored.
It does depend the bass/mid drivers response also.
What I usually mean is the design description implies either BSC
is simply ignored in the design process, or that its purposefully
ignored or limited to maintain the speakers sensitivity figure.
Fair enough if you've got tone controls and want to use them.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 20th October 2012, 03:26 PM   #29
Given your list of drivers, to use them all in a speaker would require
design of a very large 4 ohm 3.5 way, 12", 10", 6.5", 1" horn.
(the 12" and 10" specifications don't really tally with each other.)
However the 6.5" is designed for for a good 2 way with decent bass,
and not really as a high SPL midbass driver, don't know the tweeter.
rgds, sreten.
Old 20th October 2012, 03:36 PM   #30
just another
wintermute's Avatar
fair enough, and I just realised how to tell without simulating or doing any calculations, I checked the published specs of the drivers, along with his comment about the padding being about 4db. There is 3db sensitivity difference between the tweeter and the woofer so at most there could be 1db of compensation (by rolling off the bass a bit earlier, and cutting the tweeter an extra db, which isn't really going to do very much).
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Need some help on designing my speakers! Boscoe Multi-Way 4 19th February 2010 12:01 AM
designing a sub and fullrange box for several speakers... mulletdude Subwoofers 116 17th July 2009 04:31 AM
Designing PA speakers nicksmurf Multi-Way 34 15th August 2004 11:02 PM
Designing a Reference Speakers - 4 Way Active HiFiNutNut Multi-Way 11 6th June 2004 05:01 AM
help with designing speakers Wagener Multi-Way 3 29th May 2004 07:13 PM
Copyright ©1999-2013 diyAudio
