#31 | |
I had one project, where was about same picture ~600Hz. I've put notch there, got almost flat response, but after listening I removed it.
Auricap XO, Mundorf capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu |
#32 | |
BTW, I am new at this so your help is really appreciated and if I don't quite understand somethings you'll understand why . My measurement technique is to use a sine sweep and behringer RTA. I also have the ability to use pink noise but the measurement jumps around a bit so I prefer a sweep. My calibrated mic is about 5 ft from the speaker about 3 ft off the ground. Is this correct way of doing it? Thanks Much!~!~~~
#33 |
Here is an example of a parallel notch filter in series with the drivers, to deal with the "dipole peak", which is not the same as the baffle hump you get with a closed back baffle. https://sites.google.com/site/undefi...diy-sunflowers rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 11th October 2012 at 06:48 PM. |
#34 | |
It is an important discovery that the simulations do not always agree with the measurements. Two reasons. Measurements are not easy and simulations are only so good. Both are informative. The craft in speaker building is learning to interpret both and match that with your ears. The best resource to really understand speaker measurements is D'Appolito Measuring Loudspeakers. Technical for beginners, advanced users know it. It is how you get from beginner to advanced. It really helps to understand what the measurements mean. Otherwise, you won't know when the model or measurement makes no sense. I measure nearfield, one foot, 1M and listening position. I also measure on axis and at 15 degrees. I am voicing for on-axis, but looking to "fix" off axis. Subs I just measure at 1M. No reason to play around with them. This forum is fantastic at helping those who put in effort and listen. A few of us do get a little rough on people who won't put in their own effort ( That big Y in DIY) or who are convinced their bright idea that violates the laws of physics has to be correct even though they have not tried it. I am a bit of a newbee, as I have only been at it for about 35 years off and on. I do have an advantage of a degree in electronics so struggling with the technical papers from those who really do know is not quite as tough as it once was. There are quite a few folks here who make their living at this. Somehow accountants seem to have difficulty with imaginary numbers and "S" planes.
#35 | |
MLS will show you errors in crossover design as well baffle reflections - at the beginning you can understand, what is speaker response in "simulated anechoic camera". But as it is OB, you must controll, how it interacts with the room. In your measurements - nearfield is mic directly to cone - this is for you woofer, far field - about 1m from speaker on-axis. Recommend you to adjust height, that any part which can reflect (floor, ceiling, walls) must be on longer signal way. If you measure speaker at 1.6m and mic is 1m from floor you lower relable MLS measurmet will start from ~360Hz, but if you rize the speaker to 1.3m and measure from 1m it will be ~200Hz.
#36 |
TVR thanks for the honest (and sometimes humorous) response. I downloaded arta. Now I should give a complete picture of my equipment: I use a laptop. My mic is one that came with a Behringer DSP8024.
I looked at the Behringer manual I don't think it does gated measurements. Soooo, from doing a quick read of the arta help screen it looks like the mic gets connected to the laptop soundcard? Well my mic has balanced connectors. I will need to take more time to read the help (the Y in DIY . My first thought is i am going to have to find a way to go from balanced to mini plug? or just buy another mic? Just curious, can I use the arta as a gated generator and do measurements with the Behringer? |
#37 |
Opps never mind the arta help screen says NG with the laptop
| Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters | dtm1962 | Multi-Way | 10 | 8th February 2010 02:17 PM |
| Passive Notch Filter for Eminence Alpha 15As | Horizons | Multi-Way | 3 | 27th February 2009 04:22 AM |
| Passive Notch Filter For Thd Measurement | fotios | Solid State | 8 | 7th July 2008 07:29 AM |
| Notch Filter Design | ChocoHolic | Subwoofers | 36 | 13th October 2007 04:25 PM |
| passive notch filter, how much power do they take? | Puggie | Multi-Way | 4 | 3rd February 2006 01:19 AM |
