The Golden Ratio of 1.618
Old 10th October 2012, 11:41 PM   #41
Remlab is offline Remlab  United States
The primary difference between speakers and rooms is that an internal dimension of let's say 7" is going to come with standing waves that relate to a 7" wavelength. A normal room does not have standing waves at a 7" wavelength. So it is way more important to break up or absorb (Or both) the standing waves in the cabinet than to look for unrealistic room based ratios. Magnets and internal bracing are actually a good thing to combat this problem. Something similar to this;
http://www.bhphotovideo.com/bnh/cont...=437626&is=REG
would be awesome, internally.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 11th October 2012, 12:38 AM   #42
tvrgeek is offline tvrgeek  United States
I too don't care about room based ratios. I use absorbers, furniture, and bass traps. I don't have the luxury of building a room; where I do have the luxury of building speakers.
I have little belief fancy shaped diffuseness have any better performance than a piece of 1/8 ply gently bowed. But then again, I would prefer just a 4 inch thick slab of foam over 4 inch fancy convoluted cut foam. I find it works better. I stuff my sealed boxes with fiberglass and lightly stuff my ported boxes with Dacron. Seems to make take care of things well enough where other issues are more important.
Old 11th October 2012, 01:41 PM   #43
4Torr is offline 4Torr  United States
Spreading internal resonances can yield a lower frequency bass reflex f3.
The greater amount of damping material needed to quiet the resonance of, say, a 1:1:1 cabinet (one big peak) vs one with golden ratios (3 smaller peaks) will result in greater resistive loss and a less efficient bass reflex enclosure.
Old 11th October 2012, 04:15 PM   #44
1audiohack is offline 1audiohack  United States
1audiohack's Avatar
The 0.6818:1:1.618 ratio yields a 2/3 octave spread between resonances, another common acoustic ratio (come on memory) of about 0.7937:1:1,2599? splits them up by right about 1/3 octave.
As for room ratios, why wouldn't you use a proven performance ratio? The low frequency performance of a small room is definitely ratio dependent, attempts to correct afterword is not only a compromise but it is expensive.
The Golden Ratio of 1.618Hide this!Advertise here!
Sealed enclosure -- golden ratio? jmar Multi-Way 114 21st November 2017 07:50 PM
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 09:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 10:52 PM
Golden Box Ratio - Important or not? Ornlu Subwoofers 5 27th May 2005 07:52 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 09:40 PM
Copyright ©1999-2017 diyAudio
