The Golden Ratio of 1.618 - Page 4 - diyAudio
Old 10th October 2012, 08:53 AM   #31
Jmmlc is offline Jmmlc  France
R.I.P.
Hello,
Using Rayleigh formula , I simulated thousands of orthogonal parallelepipeds. I derived a graph summarizing the results.
Here it is.
The shapes (ratio length/heigh and ratio width / height) that lead to the best distributions (less audible resonances) are located on the red curve.
(Useful both to design enclosures or auditoriums)
The best dimensions of auditoriums given by Louden in his papers fall all of them on or nearby the red curve.
Ref :
Louden M.M., « Dimensions ratios of rectangular rooms with good
distribution of Eigentones » ; Acustica, 1971 ; Vol. 24 ; pp. 101-104
Best regards from Paris
Old 10th October 2012, 01:21 PM   #32
Remlab is offline Remlab  United States
Thanks! Very interesting that the "curve" is not perfectly linear and changes based on the size of the room. F. Alton Everest also covers this subject in detail(With graphs) in his book. In fact, it could probably be inferred from this "curve" that something as small as a loudspeaker cabinet would require very different ratios than an actual room..
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 10th October 2012, 01:32 PM   #33
I find it interesting that 1 x 1.5 x 2 is on the red line.
I'm intrigued with the idea that Western ears would find dissonant harmonic relationships pleasing.
Old 10th October 2012, 01:40 PM   #34
R.I.P.
Hello Remlab,
Well, the graph is independant on the absolute dimensions.
(BTW : the criterion mapped here we want to minimize is the max interval of frequency between one resonance to the next and it is expressed on the graph in Hz x height )
Only the frequency of the resonances are changing but their relation, one to the next don't. So we can say it is quite universal and can be used either for a large auditorium eitner for a smalll enclosure.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 10th October 2012, 03:37 PM   #35
frugal-phile(tm)
planet10's Avatar
Jean-Michel,
A very useful study. Thanx for posting.
Any chance you have a higher resolution graphic? (or even one in vector format?)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th October 2012, 03:47 PM   #36
badman is offline badman  United States
Custom Title
badman's Avatar
Originally Posted by planet10 View Post
The inside of a sphere has one very strong standing wave since all distances across the inside are the same. The outside is very nice.
dave
Doesn't really matter if the sphere is small enough that the magnet occupies the center, though. Plus since stuffing in the middle of a sphere would be at max velocity (where it's most effective) the inside of a sphere isn't necessarily a biggie. I'd want to be careful if the walls could "see" each other though.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 10th October 2012, 03:49 PM   #37
R.I.P.
Jean-Michel,
dave
hello Dave,
That one (see attached file) has a better resolution but the grid line and numbers doesn't have the color I wanted them to have.
Old 10th October 2012, 04:02 PM   #38
frugal-phile(tm)
planet10's Avatar
Thanx.
dave
Old 10th October 2012, 08:55 PM   #39
diyAudio Member RIP
That can't be good, as its very bad regarding coincidences of
room mode harmonics, e.g. 1(1st) = 2(2nd), 1(n) =2(2n),
1.5(3rd) = 1(2nd) = 2(4th), etc.
I can't see how a good criteria would suggest the above.
rgds, sreten.
Old 10th October 2012, 10:05 PM   #40
rgds, sreten.
Plug it into a room mode calculator and observe. Not pretty..
http://www.bobgolds.com/Mode/RoomModes.htm
The Bonello curve at the bottom of the page looks good though. Hmm..
Sealed enclosure -- golden ratio? jmar Multi-Way 65 1st February 2017 10:20 AM
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 08:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
Golden Box Ratio - Important or not? Ornlu Subwoofers 5 27th May 2005 06:52 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
Copyright ©1999-2017 diyAudio
