Horn/TL combo
Horn/TL combo
Old 23rd October 2012, 02:43 AM   #71
buzzforb is offline buzzforb  United States
buzzforb's Avatar
unless driven with a high output impedance or at high average power, I doubt you can hear a difference between AlNiCo and ceramic:
GM
Care to explain how high Zo changes things. Amps are not a problem, if there is justification for a certain type.
...Shape the sound , Man!
Old 23rd October 2012, 02:47 AM   #72
GM is offline GM  United States
GM's Avatar
Originally Posted by buzzforb View Post
Big Cal has suggested that the 421 is his favorite Altec for mids. I think that they can be reconed as a 416, but cant quite get my head around the change.
I’ve kept a ~NIB pair of 1st edition 421-8H for just this reason, but these go non-linear like right now, so strictly for low power [~50 W] in HIFI/HT apps, though can still do near THX, etc. LFE reference down to 80 Hz, so still plenty loud.
There’s been some threads on this subject on the Altec and probably on the Lansing and Audiokarma forums also.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd October 2012, 11:31 AM   #73
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
The 416 in a QW-1 enclosure would give good response well below 40Hz
and transientresponse will be a clear improvement over an ordinary vented cab.
Tall and handsome too instead of the formerly critisised short and fat Onken style box.
Ingvar
Old 23rd October 2012, 12:22 PM   #74
buzzforb's Avatar
IS this a specific enclosure or a general quarter-wave alignment?
Old 23rd October 2012, 12:36 PM   #75
It´s specific, this one actually.
Built by quite a lot of DIY friends all over the globe.
Used with all kind of drivers from todays top Pro manufacturers to
various classic units.
Actually produced commersially too.
Ingvar
Old 23rd October 2012, 01:37 PM   #76
buzzforb's Avatar
Considering that it will be a customm build, I think I will try to go with a design specific to this woofer. GM designed an MLTL for it in another thread and that's where the idea came from. I like the idea of as big a box as I can get away with. As long as I can keep the proportions acceptable, I can get away with a big box. Got a small 6 cubic feet job in the house right now that the wife doesn even flinch at.
Old 23rd October 2012, 03:42 PM   #77
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
I like that one from Ingvar ; same breed as mine from http://www.diyaudio.com/forums/pass-...ml#post3207262
am I dumber than usual , or I didn't saw that one from GM ?
I'm probably just dumber , so I can't remember where it is
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 23rd October 2012, 03:43 PM   #78
buzzforb's Avatar
Altec 416b MLTL, design by GM
Old 23rd October 2012, 04:10 PM   #79
Zen Mod's Avatar
Horn/TL combo
tnx
buzz of !
Old 23rd October 2012, 06:30 PM   #80
buzzforb's Avatar
Withot being able to see the inside of the cabinet, this desing sorta resembles the Pensil's by Scottmoose. He call them a resonant air coupler. I would expect a horn like path inside, but there is noting of the sort. What turns it int the a TL, the port? Everything I have read about TL's is that they have to do with quarter wavelength, which increases the lower you wish to tune. A TQWT can shorten this path by using a narowing line. Is this what the squaer port is doing?
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
