Horn/TL combo
Horn/TL combo
Old 24th November 2012, 07:32 PM   #371
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
so , let's just wait for tomorrow
face up/down - irrelevant
what's important is that it must be really sealed , between gasket and box
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th November 2012, 06:52 AM   #372
GM is offline GM  United States
GM's Avatar
A lot easier to measure the displacement of the face of the driver though, so face down is preferred.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th November 2012, 07:03 AM   #373
GM's Avatar
Originally Posted by buzzforb View Post
Here are the number son the cheap. Taken using added mass method....which i don't trust. Test box os glued up waiting for official test tomorrow. Does the speaker face in or out. I was assuming in, but not sure.
Fs/Qts is well matched, but Vas is way off if accurate, so depending on room conditions and how big a cab used the bass may sound a little lean on the lower Vas one.
FWIW, the Le value should be at 1 kHz, hence the very low values I questioned.
GM
Old 25th November 2012, 07:53 AM   #374
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I question accuracy, as changing the mass, changed the result. Clearly, it is a vrap shoot with that particular method.
...Shape the sound , Man!
Old 25th November 2012, 01:43 PM   #375
GM's Avatar
Yeah, just as the sealed cab needs to raise the driver's Fs at least 1.56x, so too must the added mass method lower Fs by 1.56x [0.641 x Fs], so a few quarters or steel washers isn't going to be enough. Near the end of my active building 'career', I got so lazy that I just clamped the driver to my 2.25" thick solid wood workbench since my cab alignments were typically large enough that Vas wasn't a major factor in how it performed.
GM
Old 25th November 2012, 01:45 PM   #376
buzzforb's Avatar
I had 56grams on them. About 75% of their supposed mms
Old 25th November 2012, 05:35 PM   #377
buzzforb's Avatar
Here ya go.
Route could be a little bigger and perhaps get better seal, but i would think effects are minimal
Old 25th November 2012, 06:31 PM   #378
Zen Mod's Avatar
Horn/TL combo
see ya later
Old 25th November 2012, 08:33 PM   #379
buzzforb's Avatar
So i plugged the numbers into MJK's confirmation sheet and something is clearly wrong. Using presceibed Vas from driver 1, his sheet show a much lower BL ans Mms. Odd thing is, measured numbers aren't off far from the Altec listed numbers. Tried doing it the opposite way and entering BL trying to find VAS, things are closer, but Vas is way down
Old 25th November 2012, 08:40 PM   #380
buzzforb's Avatar
Here is driver 2.
I will assume measurement error and try again, concentrating on getting nice tight seal. If they come out similar, I will just go with it.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
