Horn/TL combo
Horn/TL combo
Old 23rd November 2012, 06:49 PM   #361
GM is offline GM  United States
GM's Avatar
??? If by needing recharging, I assume you're talking about draining, re-magnetizing an AlNiCo magnet, which is indicated by an increased Qes, so driver #1 is a little 'weaker' and both are a bit 'weak' relative to any OEM 416 AlNiCo I've either measured or seen measurements of, though at least recent re-cones can be much higher, a problem that Pano and others have had.
If yours have Ferrite ['mud'] motors, then they should never need re-magnetizing unless cracked or large chunks missing, but then the frame is usually damaged also, in which case it makes a nice woodworking dead weight clamp.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd November 2012, 06:53 PM   #362
buzzforb is offline buzzforb  United States
buzzforb's Avatar
They are 416-8A's. Alnico from what i understand. If not a charge issue, what would be causing low Le.
...Shape the sound , Man!
Old 23rd November 2012, 07:06 PM   #363
GM's Avatar
Other than a measurement error, I've no clue. I mean I know that a shorting ring is the common way, but Altec only used them on the original 288 AFAIK and later diaphragm replacements require modding the driver to accept them, so can no longer be 'original', a good thing to know if ever contemplating buying some ridiculously overpriced 288s.
GM
Old 23rd November 2012, 07:19 PM   #364
buzzforb's Avatar
Maybe you are saying i should have bought new, dunno. These were a fairly good deal for their condition. Maybe not. Much less than new. Here is a pic of the cone. Is original based on all info that I have access to for the Orginal Altec 416's. Perhaps box measurement will reveal more.
Old 23rd November 2012, 07:53 PM   #365
GM's Avatar
I would have said so, if that was the case, though I have periodically posted that all things considered, buying new is a good plan if AlNiCo as there's no guarantee that they can be restored to like new.
FWIW, I've [re]zapped literally thousands of small electric motor AlNiCo, ferrite and cobalt mags and it's a real crap-shoot getting a good and especially, consistent, charge, so much time is spent redoing the worst and matching pairs, then batches, to determine their marketing value.
Note too that I only recently learned that GPA re-cones will have somewhat higher Qes/Qts by design since really low Qts motors were no longer required once very low output impedance amps became the norm, so only becomes an issue if using a SET or matching impedance amp.
Not that GPA cant't make/re-cone a low Qts motor, it can as proven by measured specs of their ferrite 515GHP series, but for 416 AlNiCo it seems to not be the norm, so I'm guessing it would have to be a [$$$] special order.
Regardless, your's Qts fall in line with Altec's later 416B published specs so good for all but matching impedance amps, so appears that you got a good deal overall if you saved some bucks.
GM
Old 23rd November 2012, 08:25 PM   #366
buzzforb's Avatar
THanks GM. Everything I have read seems to agree with your statement abour remag. Guys on audioheritage described what they called a crap shoot involving Orange county remag. Said only way to do it right was without cone. Measure, magnetize and recheck. They will be driven with a SS amp, although the F1j had crossed my mind. More likely candidate is NElson's F4. Dunno. Amps wont be a problem. THanks for the time. Forgot a jigsaw, so no box measurement tonight.
Side question. THese are rear mounting woofers. I am used to front mounting style. LYnn suggested that in 800Hz and below range it is not important for them to be flush mounted. Would you agee? One thing I notice is that the cone profile of the ALtecs are much deeper, resembling a waveguide in comparison to shallow JBL2226 profile.
Old 23rd November 2012, 11:58 PM   #367
GM's Avatar
You're welcome!
They must not do a good job draining them, or worse, don't drain them at all, which means they will never take a deep charge.
FWIW, drivers are assembled with dead magnets and magnetized right before going to the testing area, so can be drained/recharged assembled, but it's how well it's drained that matters most.
A 15" driver's cutout has a ~280-290 Hz eigenmode with a 'piston' radiation polar response around 900-1 kHz/160 deg. and a ~1265-1270 Hz pipe resonance, so tapering is strictly cosmetic below a ~760 Hz/2nd order XO point unless a very deep baffle is used.
Deeper = stiffer. Altec primarily relies on 'fast' material wave speed and doping to achieve its sonic signature whereas JBL relies more on flexure and why it has all those annular rings that each are in effect a mechanical XO.
GM
Old 24th November 2012, 12:26 AM   #368
buzzforb's Avatar
You need a chalkboard. I would definitely sit through that class. Does the deeper/stiffer altec cone allow for the use of lighter materal.
Old 24th November 2012, 02:12 AM   #369
GM's Avatar
Sure does and even with the doping they have some of the lowest Mms available for a given VC size.
GM
Old 24th November 2012, 07:06 PM   #370
buzzforb's Avatar
Here are the number son the cheap. Taken using added mass method....which i don't trust. Test box os glued up waiting for official test tomorrow. Does the speaker face in or out. I was assuming in, but not sure.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
