Horn/TL combo
Horn/TL combo
Old 22nd November 2012, 12:47 PM   #351
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Ran them for about 5 hours now. Not much has changed. I will try to get Vas measurement now. Dats has defined box method as one way. I have read that it is possible to use a sealed box of 1.5 ft^3. I can throw one together and try.
...Shape the sound , Man!
Old 22nd November 2012, 02:42 PM   #352
GM is offline GM  United States
GM's Avatar
IIRC I posted that ideally you want to raise Fs at least 1.56x if using a sealed cab to measure Vas, so short of them being wildly out of spec, then anything smaller than ~3 ft^3 should be fine for any model 414.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd November 2012, 02:46 PM   #353
buzzforb's Avatar
Ha. I am now talking about the new 416A's i have purchased. Initial pics and numbers are a couple post back. I will probably testboth when i do so, but focus is now on 416. Nothin glike dealing with a child with ADHD, huh. Take a look. I am quite pleases with their condition.
Old 22nd November 2012, 03:25 PM   #354
buzzforb's Avatar
Updated prelim numbers after 6hr break in @25Hz. Will cut a bigger hole in sealed boxes after Thanksgiving lunch.
6.33 6.54Re
26.92 26.57Fs
.315 .284Qts
.337 .302Qes
4.661 4.634Qms
.673 .761Le
Old 22nd November 2012, 04:04 PM   #355
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
you want me to run some MLTL sim ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd November 2012, 04:10 PM   #356
buzzforb's Avatar
Nope. Just reporting progress of break in. I am going to try and do this on my own insread of being lazy. I now get what GM meant by raising Fs. Didnt think about how a box can do this. Should have more info later.
Old 22nd November 2012, 04:15 PM   #357
Zen Mod's Avatar
Horn/TL combo
gimme Bl , Vas and Sd
Old 22nd November 2012, 04:33 PM   #358
buzzforb's Avatar
Gotta put the drivers in a box to get those from what little i jnow. Sd is 880, i beleve. Will check.
Old 23rd November 2012, 06:49 PM   #359
GM's Avatar
Originally Posted by buzzforb View Post
.673 .761Le
Wow! Sure is low for an Altec.
GM
Old 23rd November 2012, 07:22 PM   #360
buzzforb's Avatar
Is tgis indicative of needing recharging?
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 08:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 03:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 05:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 04:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 03:12 AM
