Horn/TL combo - Page 35 - diyAudio
Old 20th November 2012, 11:26 AM   #341
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by buzzforb View Post
Whre do you find this stuff?
Audio porn - searching for it doesn't upset the wife
Nice piccys Zen Mod.. Post 16 for a NICE horn (edit HAHA you found it too buzzforb!!)
If I'm not making noise, I'm making something to make noise
Old 20th November 2012, 08:37 PM   #342
buzzforb's Avatar
Can anyone say MINT!
Pray they measure like they look.
We'll see after BB practice.
Woofer 1
6.59 Re
26.24 Fs
.286 Qts
.305 Qes
4.469 Qms
.752 Le
Woofer 2
6.26
27.59
.318
.342
4.621
.671
Not perfect, ubt not bad either.
...Shape the sound , Man!
Old 20th November 2012, 09:20 PM   #343
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
give them some practice , then test again
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th November 2012, 09:41 PM   #344
buzzforb's Avatar
25, 30Hz sine?
Old 20th November 2012, 10:08 PM   #345
Zen Mod's Avatar
yup
but do not overpower them
+/- 1mm max
Old 20th November 2012, 10:18 PM   #346
buzzforb's Avatar
Been doing it for about 10 minutes. How long? Everything looks pretty good. Qms is a little low, but that is comparing to 416B and there are folks who say there is a difference? What has your radar perked. These things really are in wonderful shape.
Old 21st November 2012, 06:00 AM   #347
Zen Mod's Avatar
5-6 hours is minimum
but be careful with power
better longer time with lower amplitude than the other way
Old 21st November 2012, 07:12 AM   #348
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
What are the good things about an Onken style cabinet? ...as compared to a "bass reflex" or a MLTL?
Old 21st November 2012, 07:35 AM   #349
JRKO's Avatar
In 'another thread' Pano said "I like the big Onken with the Altec 416 very much. It's very tight bass, never boomy. It can tickle you like a feather, or smack you in the face. Yes, it does very well at low levels - that's one of its strong points"
Old 21st November 2012, 10:54 AM   #350
buzzforb's Avatar
I let them hum for about an hour last night. Not much changed, spec wise. These are original and not recones, so i would think Break in is a done deal. Why do you think I should run them so long if they are original. What spec has cause alarm, if any.
As for enclosure. I will probably do the Onken, eventually, but I am thinking that I will try something like a BR or MLTL first. The Onken is so big, I could do one of GM's Vb=Vas, Fb=Fs, ideas. I will probably start with a BR in the 10ft^3 area and work from there. It will be an easy box and will give me an idea of the drivers abilities. The exemplar is on the radar as well. Since i finally got the driver I was looking for, I will try multiple boxes unless the first one is just awesome and i have no desire to continue...not likly. I will also keep my eyes peeled for a set of 515's. There ar some now on the bay that need reconing at only $575, but the shipping kills you. E-Bay want let me ship directly to GPA.
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
Copyright 1999-2017 diyAudio
