Horn/TL combo
Horn/TL combo
Old 19th November 2012, 09:54 PM   #331
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
frankly - only heard derivative of it - biggest Tannoys like that - monitors of yore
other big buzzin woofs I had opportunity to hear , were working almost at treshold of pain
or maybe even louder , but I was toxicated anyway
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th November 2012, 10:03 PM   #332
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Everything i read about the jbl 4355 was that they were loud. Who gives a s^$% about loud. Loud is easy and pointless, unless your in a monster room or big field. I just thought it my be interesting for dynamic impact, but not if you give up detail and delicacy in return. Would help match better with horn from efficiency standpoint. Two 416's under the 290 Iwata might be interesting. Gotta a Iwata derivative I am working on using LeCLeach spreadsheet. I think it might be the only one. That probably only means they will suck
...Shape the sound , Man!
Old 19th November 2012, 11:17 PM   #333
GM is offline GM  United States
GM's Avatar
Originally Posted by buzzforb View Post
What kinda imaging would one expect from side by side woofers?
Better overall than singles because they are more focused horizontally and less so vertically, blending better to a large ~90 x 40 horn.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th November 2012, 11:19 PM   #334
GM's Avatar
What do you expect? JBL = Just Big & Loud.
GM
Old 19th November 2012, 11:22 PM   #335
buzzforb's Avatar
GM
That's pretty good. Never heard it before.
GM
So, when they speak of the jbl 4355 having not so great imaging, do you think it is related to the fact that the horn and midrange are in the middle of a very large baffle.
Barring the 515's, what do you thin about dual 416's under the 290 Iwata. It is basically a 90 horn in the horizontal plane.
Old 20th November 2012, 12:06 AM   #336
GM's Avatar
I know nothing about the 4355, just what I know from experience after auditioning a pair of Lagunas and later a pair of 9844s, though for sure you can't use as high an XO point as you can with a single or vertically oriented dual woofers: http://www.hifilit.com/hifilit/Altec/1959-h.jpg
http://altecpro.com/pdfs/vintage/Spe...r%20System.pdf
GM
Old 20th November 2012, 10:42 AM   #337
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Hey buzzforb - here's some Altec bass type inspiration
http://www.diyaudio.com/forums/multi...ml#post3248516
If I'm not making noise, I'm making something to make noise
Old 20th November 2012, 11:13 AM   #338
buzzforb's Avatar
Whre do you find this stuff? That is clearly re-branded Altec/GPA. I am probably looking at 9-10ft^3 for my woofer and will go a little taller as well, as the Iwata is not as big vertically. Thanks for the info.
Old 20th November 2012, 11:19 AM   #339
Zen Mod's Avatar
Horn/TL combo
was this already posted : HORNS - HiFi Chile ?
use Gchrome for auto trans
Old 20th November 2012, 11:23 AM   #340
buzzforb's Avatar
THank you ZM. THis is becoming collecting spot for cool speaks.
This one looks interesting.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
