Horn/TL combo
Horn/TL combo
Old 12th November 2012, 05:17 PM   #321
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I have asked some questions about re-coning. Nothing. I guess I am used to this place, which is more heavily trafficked. No worries though. I am suppose to receive the 414's Tuesday, but that is appx. I may take my horn blanks and slap some sides on them and mount up the horns just to give a listen. Why not.
...Shape the sound , Man!
Old 12th November 2012, 05:22 PM   #322
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Why not indeed!!!! cant wait to 'hear' you reaction & thoughts
As for Audioheritage its a smaller fan base than here by some margin. Have you spoken to Bill at GPA about recones etc? - super guy. I called him from the UK for a few question I couldn't get answered on AH
If I'm not making noise, I'm making something to make noise
Old 12th November 2012, 05:23 PM   #323
buzzforb's Avatar
Not had a chance, although it will happen soon, as I have some recone work for him as well.
Old 15th November 2012, 10:23 PM   #324
buzzforb's Avatar
Got the 414's in. Two tested OK. Two have voice coil rub. Seller refunded money for bad two. Dont think I will use them, as the plan was for dual woofers. Dont feel like reconing them either. Will probably just sell them.
Free Air measurements on two that work
Driver 1 Driver 2
10.374 10.943 Re
37.01 37.01 Fs
.327 .284 Qts
.401 .322 Qes
1.792 2.392 Qms
1.001 1.368 Le
Haven't done the VAS test, as I cant figure a good way. Nickel trick is difficult with vented dsut cap. May try box volume test with 75ltr boxes I have. Dunno if its even worth it.
Old 15th November 2012, 11:11 PM   #325
GM is offline GM  United States
GM's Avatar
Got any old toroid inductors? Small hubcaps? Coils of solder, wire?
The main thing is to lower Fs by at least 0.64x. The most accurate way is to raise Fs by 1.56x in a sealed cab, then multiply the cab's net Vb by 1.44x.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th November 2012, 12:46 AM   #326
buzzforb's Avatar
i am using DATS system from PE and have not done this before, so that is Klingon to me. I will do some reading.
Old 19th November 2012, 09:33 PM   #327
buzzforb's Avatar
What kinda imaging would one expect from side by side woofers? Been looking at the JBL 4345 and 4355 and Just happened to find an Altec version of the JBL 4345, using 416,414,and late model comp driver that is not well knWn. Although I will have all the parts, I have read multiple opinions that say they just dont like the 414 as much as 416 or 515 in the midrange. Having the 416's and 288 on big horn, seems like a waste to use 414. Guess it is question of what you want doing the vocals, horn or woofer. Wednesday should bring numbers on the 416's
Old 19th November 2012, 09:35 PM   #328
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
buzz - you have a PM
or e-mail
whatever
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th November 2012, 10:45 PM   #329
Zen Mod's Avatar
Horn/TL combo
what you mean by side by side ?
Old 19th November 2012, 10:48 PM   #330
buzzforb's Avatar
Onken W, JBL 4355....side by side 15" woofers.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 08:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 03:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 05:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 04:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 03:12 AM
