Horn/TL combo
Horn/TL combo
Old 12th November 2012, 06:36 AM   #311
GM is offline GM  United States
GM's Avatar
Originally Posted by JRKO View Post
I think a 3rd or 5th of the room dimension
Correct.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th November 2012, 08:08 AM   #312
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Horn/TL combo
Originally Posted by ra7 View Post
...... get a kick out of this.....
thats the real listening position
Old 12th November 2012, 08:38 AM   #313
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
.......might get a kick out of this:
The words soundstage & imaging come to mind.
You'd have to play it safe with the volume or else you'd end up like a fly on a windscreen {SPLAT}
If I'm not making noise, I'm making something to make noise
Old 12th November 2012, 09:41 AM   #314
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by GM View Post
Correct.
GM
Meaning that these positions are to be avoided or attempted. Found many articles on the web, but nothing that fully explains how to position to avoid these issues. If thirds andfifths are too be avoided, vertically i want to stay away from 19",32",38"57",and 64". Am i correct in thinking that this is mainly a LF issue?
...Shape the sound , Man!
Old 12th November 2012, 10:38 AM   #315
JRKO's Avatar
'Odd' is good.
Old 12th November 2012, 10:48 AM   #316
buzzforb's Avatar
Thanks JRKO
Old 12th November 2012, 03:21 PM   #317
GM's Avatar
In the vertical plane? No, it will affect the entire BW to a greater or lesser extent due to how it affects early reflections.
GM
Old 12th November 2012, 03:27 PM   #318
buzzforb's Avatar
Ill do some more reading.
Old 12th November 2012, 03:33 PM   #319
GM's Avatar
'Odd' is good.
Yep, 3rds, 5ths are most common positions, though recent changes in THX, DD True HD reference LP, speaker system locations may require using higher orders in reference HT apps.
So many folks today sit way too far away from HD systems to get the full benefit of the high resolution available, especially WRT 1080P displays and now there's 4k and higher being developed. Great if you have a small cinema size screen or watch movies < a crooked arm's length away from a computer monitor, but otherwise?
GM
Old 12th November 2012, 04:03 PM   #320
JRKO's Avatar
My big beef with HD is it essentially asks people to replace their TV's with already outdated picture quality (1080x1920 soooo last decade) all the time masking the fact that TV programming has gone down the drain and 'blockbusters' are HD drivel with CGI for brains
mmmmmm - thats why we build BIGA$$ speakers!!!
When do your drivers arrive buzzforb? What problems where you having on the audioheritage site?
James
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
