Horn/TL combo
Horn/TL combo
Old 10th November 2012, 06:50 PM   #301
Russellc is offline Russellc  United States
Horn/TL combo
Originally Posted by buzzforb View Post
I have read that quite a few folks like the 515G the best of all Altec's. We will see. I have quite a few drivers to try.
True they do. But in the end, like ZenMod suggested earlier, I stuck with the 416 8C. The only thing I found them better for was selling, better market. At the Time GM advised opposite, I claimed more LF extension, he said, and no doubt right, I just needed equalization. I went simpler route, sold 515 8G and kept 416 8c. They all sound good, just my A7 boxes were so big, adding giant subs just seemed redundant. So I left A7s to basement system, built Econowaves with JBL bass and box, B&C compression on top. Never looked back, although this is tickling my interest again! Continue!
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 10th November 2012, 06:54 PM   #302
Horn/TL combo
Problem for me is room size and listening distance.
That's what steered me to the Econowave route....at the time, room size was 12 x 17....larger now, basement room with A7s is larger still. But its in the basement!
Russellc
Old 11th November 2012, 09:21 AM   #303
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Russellc
I would also like to try h9800 clone, but cant get audioheritage guys to even respond.
...Shape the sound , Man!
Old 11th November 2012, 05:57 PM   #304
buzzforb's Avatar
Try 1 and Try 2. Will not use either, probably. More about getting jig straightened out and the routine working smoothly. Now feel much better about how to go about it, so I will start on actual horn.
Old 11th November 2012, 07:21 PM   #305
buzzforb's Avatar
I am thinking about the final enclosure and have a question. What is the ideal listening height for the horn center point. Would having it at appx 48", half the total height of the room, be better or worse for room reflections and such?
Old 11th November 2012, 07:47 PM   #306
GM is offline GM  United States
GM's Avatar
Conventional wisdom says to make it at the average seated ear height, but room height is no different than width or depth WRT Eigenmodes, so if 3rds, 5ths are appropriate for the LP location[s], then doesn't it seem reasonable that the same would apply to a speaker's vertical acoustic center?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th November 2012, 07:55 PM   #307
buzzforb's Avatar
3rds and fifths are above my understanding. Ear height is understood, but since i was designing from the ground up, there was flexibility, so i thought i would ask if there was a more ideal scenario.
Old 11th November 2012, 08:08 PM   #308
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
I think a 3rd or 5th of the room dimension
great effort on the born section BTW. Any pics of the jig/router setup?
If I'm not making noise, I'm making something to make noise
Old 11th November 2012, 10:49 PM   #309
TerryO is offline TerryO  United States
TerryO's Avatar
GM
I agree completely.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 12th November 2012, 04:36 AM   #310
ra7 is offline ra7  United States
Horn/TL combo
Thought ZM, Cal, Pano, and others might get a kick out of this:
Altec Voice of the Theater Speakers
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
