Horn/TL combo - Page 28 - diyAudio
Old 7th November 2012, 10:07 AM   #271
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
we'll know more when you give us exact measured T/S , but I'm not expecting small boxes however ; what's dictating size is F3 and , combined with certainly not so low Vas ......
so - with 2 per side , it will go bigger than with one 15" , most probably , while I'm not expecting that solution significantly superior to one 15"
remind me ( yakyak , multitasking & multithreading , while I'm dumb ) where in thread are T/S for these JBLs ?
what I'm urging you all the time , is to go TQWT or MLTL ( whatever , I'm too dumb to differentiate them properly ) and leave plain BR for non-unitiated ones
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th November 2012, 10:12 AM   #272
buzzforb's Avatar
Fs-20
Qts - .21
Qms - 1.8
Qes - .41
Vas - 736.2
re - 8.8
Le - 2.2
BL - 22
MMS - 97
...Shape the sound , Man!
Old 7th November 2012, 10:30 AM   #273
Zen Mod's Avatar
something's wrong
while inputing data in MJK ML TL sheet , I'm getting Qts of 0.334 from rest of data
Old 7th November 2012, 10:48 AM   #274
buzzforb's Avatar
Qms is supposed to be 5.5, Qes is .21. Sorry, typing on phone.
Old 7th November 2012, 11:04 AM   #275
Zen Mod's Avatar
then later , this evening
gotta go
Old 7th November 2012, 01:59 PM   #276
GM is offline GM  United States
GM's Avatar
Originally Posted by buzzforb View Post
I wasn't saying looks had something to do with it, but speculating that in a long narrow room, continuing to back up further might not help because room reflections would come into play even more.
Again, speaker directivity [polar pattern] combined with proper toeing in and vertical height location limits these to a BW low enough to where they are down where our hearing acuity is falling off enough to not be an issue.
The closer you sit, the more you have to pull the speakers away from the side walls and the narrower the 'sweet spot' for a given speaker directivity.
Assuming you’ve chosen a ‘good enough’ directivity design for the speaker/LP ‘triangle’, worst case is you may need a nice thick area rug if you have a hard floor and maybe some decorative wall hangings near the speakers.
Whatever you do, don't have any reflective objects between the speakers and LP. I've auditioned/seen many otherwise properly done systems that were totally compromised by a coffee and/or end tables and/or a ‘lowboy’ front projector.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th November 2012, 03:26 PM   #277
GM's Avatar
Fs-20
Qts - .202
Qms - 5.5
Qes - .21
Vas - 736.2
re - 8.8
Le - 2.2
BL - 22
MMS - 97
Which driver? Sd used?
GM
Old 7th November 2012, 04:38 PM   #278
buzzforb's Avatar
Jbl le15a
Sd is 880
Old 7th November 2012, 05:22 PM   #279
Zen Mod's Avatar
hehe
I'm wisely steppin ' aside
Old 7th November 2012, 05:30 PM   #280
Zen Mod's Avatar
buzz - not so bad results in same box I'm gonna use for my Tanns
NB that few details/dims are still missing on pic , but that's it in principle
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
Copyright ©1999-2017 diyAudio
